regex and grouping questions
Carlomd
Hi all, I have a 5510 in route mode, when I add a regex to block 2 sites, it somehow blocks all sites, when I remove it it's back to normal, here's the regex code along with my other nat setting that gives inside users outside access. Thanks in advanced.
(regex entry to block sites)
regex domain1 "\.yahoo\.com"
regex domain2 "\.google\.com"
class-map type regex match-any domain-list
match regex domain1
match regex domain2
class-map web
match port tcp eq www
policy-map type inspect http URL
parameters
match not request header host regex class domain-list
drop-connection
policy-map global_policy
class web
inspect http URL
(nat outside access)
object network obj-LAN
subnet 0.0.0.0 0.0.0.0
nat (inside,outside) dynamic interface
route outside 0.0.0.0 0.0.0.0 12.54.x.x 1
47 Replies 47
Hehe...
imp = icmp
Please remember to select a correct answer and rate helpful posts
On the icmp thing, I didn't have an acl for any inside clients but  servers only, so shouldn't the global rule for inspect icmp work then?
The ACL will take precedence over the inspect rules, so your ICMP traffic is bing dropped by the global ACL.  You need to have an ACL on the interface for ICMP traffic to work.
access-group ACL_OUT in interface outside
access-group ACL_IN out interface inside
It looks as though your ACL_IN is configured in the wrong direction.  As it is configured now traffic entering the ASA will be checked once on the ACL-OUT ACL and then again when it leaves the inside interface, it will be checked against the ACL_IN ACL.  Change it to the following:
access-group ACL_IN in interface inside
I am no email expert and am not 100% sure how the ports are sent, but as a rule you should always specify the ports on the destination and not the source.
access-list ACL_IN extended permit tcp object-group MAILSERVERS object-group TCP any
access-list ACL_IN extended permit udp object-group MAILSERVERS object-group UDP any
Normally PC and servers send using a random high number source port with a destination of a wellknown port.  The only time I have seen a server send with a source well-known source port is with Microsoft Lync.  I would try to test by changing the ACLs around so that the ports match on the destination.
Other than that the NAT for the RDP host and the ACL for RDP look fine.  I think by correcting the access-group statements that many of your issues will be solved, and that changing up the mail server ACLs to match the port on the destination should also sort that problem out.  If not let us know and well shall look at this further.
Please rate all helpful posts.
Hi Marius,
The object group TCP has smtp dns and http in it, I took out UDP as my old firewall didn't have it for outgoing, yeah I jacked my access-group with the wrong command syntax, I thought to tell the asa to allow outgoing is to use the out command for the outside interface. But that actually broke my incoming emails and web access, so I took it out, and it worked, but I still need to get smtp and dns from those email servers and dns servers to get out to of the asa, so it would be in int inside, I'll try it again, thanks.
Let us know how it goes
Hi Marius,
Finally back on this again, here's my latest config, incoming web, email, and rdp all works(I'll figure out how to block by ip for websites later on), only issue is accessing our OWA server from inside, I changed my acl-in group to access-group ACL_IN in interface inside like what you advised, but that didn't work.
It blocked outgoing access to websites and icmp pings(email and rdp continued to work though). As soon as I took out any outgoing access lists and group it worked again. You'll notice on the last access list, it has an outgoing rule(was thinking that would alllow access to our owa server from inside, but same results)
Is there something wrong with my config, I noticed it doesn't seem to like any outgoing access list.
crxasa# sh run
: Saved
ASA Version 9.1(2)8
hostname crxasa
domain-name domain.com
enable password 5wq4IltsegGVfI30 encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
ip address 12.x.x.34 255.0.0.0
interface Ethernet0/1
nameif inside
security-level 100
ip address 208.x.x.1 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
management-only
nameif management
security-level 15
boot system disk0:/asa912-8-k8.bin
ftp mode passive
clock timezone PST -8
clock summer-time PDT recurring
dns domain-lookup inside
dns server-group DefaultDNS
name-server 208.x.x.12
domain-name cirexx.com
object network cirexxintldc
host 208.x.x.12
object network sharks
host 208.x.x.5
host 208.x.x.85
object network crxmail
host 208.x.x.3
object network svr-sales
host 208.x.x.94
object-group service TCP tcp
description domain,http,smtp services
port-object eq www
port-object eq https
port-object eq domain
port-object eq smtp
object-group service WEBSERVER tcp
description ftp,http,https services
port-object eq www
port-object eq ftp
object-group network MAILSERVERS
network-object host 208.x.x.12
network-object host 208.x.x.3
object-group network DNS-SERVERS
network-object host 208.x.x.5
object-group service UDP udp
port-object eq www
access-list ACL_OUT extended permit tcp any host 208.x.x.85 object-group WEBSERVER
access-list ACL_OUT extended permit tcp any host 208.x.x.94 eq 3389
access-list ACL_OUT extended permit tcp any object-group MAILSERVERS object-group TCP
access-list ACL_OUT extended permit icmp any any echo-reply
access-list ACL_OUT extended permit icmp any any unreachable
access-list ACL_OUT extended permit icmp any any time-exceeded
access-list ACL_OUT extended permit tcp object-group MAILSERVERS object-group TCP any
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-714.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,outside) static 12.x.x.35
nat (inside,outside) static 12.x.x.37
nat (inside,outside) static 12.x.x.36
nat (inside,outside) static 12.x.x.43
nat (inside,outside) static 12.x.x.49
route outside 0.0.0.0 0.0.0.0 12.x.x.33 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 0.0.0.0 0.0.0.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 management
ssh timeout 30
ssh version 2
ssh key-exchange group dh-group1-sha1
console timeout 30
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
username admin password zULPhOeRwWoy3VJE encrypted privilege 15
class-map inspection_default
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
  inspect icmp error
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:e61d1c3cad33310155ac2216db60fdef
: end
When accessing the OWA site i assume you are using the URL?  What IP does the URL go to, the external IP or the actual private IP (do an nslookup mail.domain.com change the URL to match your actual url)?  It looks as though your mail servers are also located on the inside interface?
If your Mailservers are located on the inside interface along with all your hosts then your only option would be to add an A record to your DNS server that points the URL to the mailserver's private IP.
Please remember to rate and select a correct answer
I have split dns, when I go to my owaserver.com it points to an outside ip, my dns and mailservers are inside, I have an A record already pointing to my inside ip for the mailserver, the mailserver is nat'ed on the ASA. This all works on the old firewall by the way, I have dns outgoing, which is needed for our network to function, but I can't seem to get this to work on the ASA.
I made another change on the config to see if dns gets out(my 2 dns servers in the bottom for outgoing using tcp and udp), somehow I can't get to our OWA mailserver, all work fine from outside by the way, only from inside we can't. Thanks in advanced
access-list ACL_OUT extended permit tcp any object-group REMOTEUSERS eq 3389
access-list ACL_OUT extended permit udp object-group DNS-SERVERS any eq domain
access-list ACL_OUT extended permit tcp object-group DNS-SERVERS any eq domain
Split DNS is for VPN users where you define specific URLs that are to be resolved over the VPN connection.
So you say you have an A record for the OWA URL? for example you have an entry for mail.company.com pointing to 208.x.x.3 or 208.x.x.12?
The issue you are facing is that your inside hosts are trying to connect to the OWA using the public address.  So traffic is routed to the outside interface and then does a u-turn and comes back in.  The ASA views this as spoofed / not allowed and drops the connection.
You will need to set up hairpinning and NAT from inside to inside.
object network MAIL-SERVER-EXTERNAL
host
object network MAIL-SERVER-INTERNAL
host
object network LAN
subnet 208.x.x.0 255.255.255.0
same-security-traffic permit intra-interface
nat (inside,inside) source static LAN LAN desitnation static MAIL-SERVER-EXTERNAL MAIL-SERVER-INTERNAL
  Yes, we split it since we started with public ip's, our owaserver.com A record is an outside ip which is mip'ed to the inside real name that points to the inside ip's.
  I read and tried dns doctoring but with same results, also read about hairpinning but haven't tried yet, though I heard from another thread that it has risks, but we do have some users that use OWA, so I need to get that working. I'll give hairpinning a try. This will be it once I get it working, I can fully switch to the ASA, thanks again Marius.
  Marius, I gave it a try, it didn't work, it actually blocked access to our main website, here's the code, do you think it conflicts with the current lan nat entry?
I saw another thread that talks about hairpinning in a recent post, the forum member has this for the nat statement "nat (inside,inside) 1 source static internal interface destination static Public_Server Private_Server"
crxasa# sh run object
host 208.x.x.12
host 208.x.x.5
host 208.x.x.85
host 208.x.x.3
host 208.x.x.94
object network randy
host 208.x.x.84
object network jana
host 208.x.x.133
object network carlo
host 208.x.x.30
object network mb1.cirexx.com
host 12.x.x.35
object network LAN
crxasa# sh run nat
nat (inside,inside) source static LAN LAN destination static mb1.cirexx.com cirexxintldc
nat (inside,outside) static 12.x.x.54
object network jana
nat (inside,outside) static 12.x.x.44
nat (inside,outside) static 12.x.x.53
It is most likely that the new twice NAT statment interfers with the existing dynamic NAT statement.
You could try the following
nat (inside,inside) source static LAN interface destination static mb1.cirexx.com cirexxintldc
I changed it but got this warning;
crxasa# con t
crxasa(config)# nat (inside,inside) source static LAN interface destination static mb1.cirexx.com cirexxintldc
WARNING: All traffic destined to the IP address of the inside interface is being redirected.
WARNING: Users may not be able to access any service enabled on the inside interface.
That warning comes due to the dynamic NAT statement you already have.  If you are connected remotely, then I would suggest not applying this config at this time.  It would be best to do this when onsite and have physical access to the ASA incase you lose connectivity.  once you apply it, if traffic flow to the internet and to the all other resources are as expected then you can keep the configuration.  If not then remove it, of course.
  I'm onsite, we do have remote users that could get disconnected, I found this article that has additional configs to get it right, I'll give these a try - https://supportforums.cisco.com/docs/DOC-13728
Keep in mind that the configuration in that article is for ASA 8.2 and earlier.  The same configuration will not work on your ASA running version 9.1
