regex and grouping questions
Carlomd
Hi all, I have a 5510 in route mode, when I add a regex to block 2 sites, it somehow blocks all sites, when I remove it it's back to normal, here's the regex code along with my other nat setting that gives inside users outside access. Thanks in advanced.
(regex entry to block sites)
regex domain1 "\.yahoo\.com"
regex domain2 "\.google\.com"
class-map type regex match-any domain-list
match regex domain1
match regex domain2
class-map web
match port tcp eq www
policy-map type inspect http URL
parameters
match not request header host regex class domain-list
drop-connection
policy-map global_policy
class web
inspect http URL
(nat outside access)
object network obj-LAN
subnet 0.0.0.0 0.0.0.0
nat (inside,outside) dynamic interface
route outside 0.0.0.0 0.0.0.0 12.54.x.x 1
47 Replies 47
Even if it says 8.2 onward
8.2 onwards:
Configuring NAT for both subnets (without nailed option):
nat (inside) 1 192.168.1.0 255.255.255.0
global (inside) 1 interface
static (inside,inside) 172.16.10.0 172.16.10.0 netmask 255.255.255.0
same-security-traffic permit intra-interface
sysopt noproxyarp inside
It is quite deceiving, it should say 8.3 and onwards if it is refering to the new way of configuring NAT.  The configuration you posted is pre 8.3.
https://supportforums.cisco.com/docs/DOC-9129
Please remember to rate and select a correct answer
Please remember to select a correct answer and rate helpful posts
It's working now, I'll open a new thread for my blocking sites questions, thanks for all the help Marius
