06-04-2004 01:34 PM - edited 02-20-2020 11:26 PM
I am running a few PIX 501 using Network Extension Mode (NEM) connecting to a Cisco 3000 Concentrator.
I am having trouble setting up a pix in NEM to accept ssh connections for remote management.
I have several pixes setup using a non-nem config and I can SSH into them just fine. The NEM pixes use NEM and DHCP to pull an IP address. Is it even possible to set up remote management since I can't specify the outside IP or is there any way to setup ssh remote management so that I can ssh to the inside IP from behind the concentrator.
Currently I have to remotely log on a pc behind the Pix and then telnet to the inside IP to manage the pix.
06-10-2004 10:34 AM
I could not find any bug related to SSH when PIX is setup in NEM. I guess, you are probably running into a configuration issue.
08-19-2004 12:53 PM
i am trying to setup several PIX 501's using NEM. i get my tunnel established but cannot get any traffic flow. do you have a config you could show me, and maybe some settings on the 3030 i am missing?
