Requirement to shutdown FTD inside interface via SLA
We have a requirement to shutdown the inside interface of our FTD once the internet link on the upstream ISP router goes down. The logical connectivity is as follows.
Core Switch---->(inside)FTD(outside)----->(inside)ISP Router(outside)----->Internet
Initially I planning to use an sla monitor (ping to 8.8.8.8)and use it in an EEM script to shutdown the interface. But I found that FTD/ASA does not support event track command. Please advise if there is any other way to achieve my requirement.
32 Replies 32
The below is what I've setup. It is working perfect.
As soon as the 8.8.8.8 is unreachable, the interface e1/3 goes down.
as soon as the 8.8.8.8 is reachable, the interface e1/3 goes up.
# Create a static route to reach 8.8.8.8
route outside 8.8.8.8 255.255.255.255 x.x.x.x
# Create IP SLA to PING 8.8.8.8
sla monitor 10
type echo protocol ipIcmpEcho 8.8.8.8 interface outside
frequency 10
sla monitor schedule 10 life forever start-time now
# Create tracking and link it to the SLA
track 1 rtr 10 reachability
# Create a static route to reach 8.8.4.4 with the tracking
route outside 8.8.4.4 255.255.255.255 x.x.x.x 1 track 1
# Create two EEM instances to shutdown the interface e1/3 and bring it back up
event manager applet DMZ-Down
description "ShutDown Interfaces"
event syslog id 317078
action 1 cli command "enable"
action 2 cli command "config t"
action 3 cli command "interface Ethernet1/3"
action 4 cli command "shutdown"
action 5 cli command "end"
action 6 cli command "wr"
output none
event manager applet DMZ-Up
description "Up Interfaces"
event syslog id 317077
action 4 cli command "no shutdown"
output none
It seems I was too fast by saying the setup I made works perfect. It was running OK at the beginning, however, later it caused the interface e1/3 to flop (Up and Down). Moreover, the Controle CPU increased up to 80%. So, don't try this setup in production. I'm very sorry for the confusion.
Apologies for the late response. I used two scripts and used occurrence value as 2 in the second script which will bring the interfaces back. I have monitored it for around 2 months and seems to work fine. Thanks a lot guys for your support.
