Setting up Pix 515 with 3 interfaces and a remote location.
dennisb
I have a problem setting up a pix for one of our customers.
The network i'm dealing with consist of a 1602 router on the outside, the pix, an inside network and a DMZ.
The DMZ is my problem. The following is connected to the ports of the pix:
Outside port: Cisco 1601 router
Inside port: 3com switch
DMZ port: cisco 1720 router (locally) connecting via T1 static line to another 1720 router at a remote location.
Now, we are supposed to use nat, which is fine with me. I chose a range of 10.0.0.x for the inside and a range of 10.0.1.x for the DMZ (to have different subnets). How can i make the DMZ remote part work with the pix through the 2 1720 routers?
The pix is not in place yet, this is all theoretically.
The configs:
Pix:
PIX Version 6.1(1)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security50
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname kkfirewall
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
pager lines 24
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip address outside 12.x.x.131 255.255.255.192
ip address inside 10.0.0.2 255.255.255.0
ip address dmz 10.0.1.2 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 12.x.x.132-12.x.x.190
global (outside) 1 12.x.x.191
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,dmz) 10.0.0.0 10.0.0.0 netmask 255.255.0.0 0 0
static (inside,outside) 12.x.x.130 10.0.0.130 netmask 255.255.255.255 0 0
conduit permit icmp any any
conduit permit ip 10.0.0.0 255.255.0.0 10.0.1.0 255.255.255.0
conduit permit tcp host 12.x.x.130 eq www any
conduit permit tcp host 12.x.x.130 eq smtp any
conduit permit tcp host 12.x.x.130 eq pop3 any
conduit permit tcp host 12.x.x.130 eq ftp any
conduit permit tcp host 12.x.x.130 eq ftp-data any
conduit permit udp host 12.x.x.130 eq dnsix any
conduit permit tcp host 12.x.x.130 eq telnet 12.0.170.0 255.255.255.0
conduit permit tcp host 12.x.x.130 eq 7000 12.0.170.0 255.255.255.0
route outside 0.0.0.0 0.0.0.0 12.x.x.129 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
telnet 10.0.0.130 255.255.255.255 inside
telnet 10.0.0.130 255.255.255.255 dmz
telnet timeout 15
ssh timeout 5
terminal width 80
Cryptochecksum:f639ac1bf840fa2c1adae3cdcaff4b24
kkfirewall(config)# route dmz 10.0.1.0 255.255.255.0 10.0.1.3
Route already exists
kkfirewall(config)#
I had to replace the real outside IP partly with "X" in this, because the customer does not want their IPs published.
I can also post the suggested setup for the 2 1720 routers if that helps...
Also, the DMZ uses Appletalk (and has to continue to use it). Can i use appletalk (the 1720 supports it) and still be able to communicate from the DMZ to the inside?
murabi
Level 4
Level 4
I know Appletalk won’t go through the PIX as it’s an IP only box. You might be able to tunnel Appletalk through GRE if you have a tunnel endpoint inside. You’re also using a network static static (inside,dmz) 10.0.0.0 10.0.0.0 netmask 255.255.0.0 0 0 for all your inside hosts to appear on the DMZ with their own addresses but you have you DMZ numbered with a 10.0.1.x class C which will likely cause a problem with your network static. You might consider something completely different like 192.168.1.x for the dmz or at least 10.2.x.x. So there’s some places to start troubleshooting. Good luck.
jldediego
Hello.
Maybe you need as well, another static route at the pix dmz interface, to communicate with the remote dmz, otherwise you won't be able to send anything from the inside to de remote dmz, through the intermediate dmz and 1720 routers.
Something like this at the pix:
route dmz subnet_ip_addres_remote_dmz ip_address_1720_attached_to_close_dmz
Hope this help as well.
Regards.
José Luis De Diego González.
