Smart Licensing <Device is not registered> <Communication message send
amh4y0001
Level 3
Level 3
Trying to license a Cisco Firepower 1100 series. Yesterday I did registered one device successfully but today it's not being registered. Both devices are same model.
I have ensured that:
1. WAN link is up and properly configured.
2. Default Route exists (correct value exists).
3. DNS has been configured and enabled on outside interface (WAN)
4. Can ping tools.cisco.com
See below for detailed information and advice what might be causing the issue?
FW3(config)# show license all
Smart Licensing Status
Smart Licensing is ENABLED
Registration:
  Status: UNREGISTERED - REGISTRATION FAILED
  Export-Controlled Functionality: NOT ALLOWED
  Initial Registration: FAILED on Jul 07 2023 13:38:43 ???
    Failure reason: Communication message send error
License Authorization:
  Status: No Licenses in Use
Export Authorization Key:
  Features Authorized:
    <none>
Utility:
  Status: DISABLED
Data Privacy:
  Sending Hostname: yes
    Callhome hostname privacy: DISABLED
    Smart Licensing hostname privacy: DISABLED
  Version privacy: DISABLED
Transport:
  Type: Callhome
License Usage
No licenses in use
Product Information
UDI: PID:FPR-1120,SN:JA*****QL
Agent Version
Smart Agent for Licensing: 4.9.3_rel/34
Reservation Info
License reservation: DISABLED
DNS Server
DNS Server is set on outside interface (WAN)
Ping tools.cisco.com
FW3# ping tools.cisco.com
Sending 5, 100-byte ICMP Echos to 72.x.x.38, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 120/128/130 ms
Successfully ping the tools.cisco.com
amh4y0001
Level 3
Level 3
Surprisingly, device is now registered. I haven't made any changes ...strange for me.
Thanks everyone for the contribution, appreciated.
7 Replies 7
Did you check that the licenses are showing in your smart account and that they are available?, if so, I would check the certificates that have been imported into the device that was successfully registered and import them into this one.
@Aref Alsouqithanks for reply.
, >>> Today created a NEW Token and used that instead but that didn't worked either. Please note that I was able to register flawlessly in past.
I would check the certificates that have been imported into the device that was successfully registered and import them into this one. >> Don't know exactly, do you have steps to follow (if it's worthy to check).
Generating tokens wouldn't help if you don't see the required certificates in the smart account. Regarding the certificates, it would be enough to look at the trusted certs on the functional one.
 if you don't see the required certificates in the smart account. >>> And how I can verify that?
Here is how my Smart Account looks like:
Sorry I meant to say if you don't see the required licenses not certificates. You can see the licenses in the Licenses tab next to general.
For me, it looks like I still have 11 licenses to be consumed.
The following screenshot depicts the device that were registered yesterday. And I can see 11 devices more can be registered.
amh4y0001
Level 3
Level 3
