SNMP using FDM - supported interfaces
Sudqi
Level 4
Level 4
Hello Experts,
Are all interfaces supported to be a source for the SNMP using FDM?
if we can use the tunnel interface, how can we know the API related to this interface to put the details inside the SNMP-host
FTD 1120, version 7.2.5.2
balaji.bandi
Check the below guide, you can bind to the interface which can listen the API calls. never tried Tunnel interface, may be you can test  :
https://www.cisco.com/c/en/us/support/docs/security/firepower-ngfw/216551-configure-and-troubleshoot-snmp-on-firep.html
wider guide :
https://www.cisco.com/c/en/us/support/docs/ip/simple-network-management-protocol-snmp/213971-configure-snmp-on-firepower-ngfw-applian.html
BB
Thanks for your input Balaji,
I saw these guides but it is explain the method using Ethernet interface,
I am wondering for the tunnel, I didn't found if its doable or not, the MGMT interface is not doable from the guide
