Sql connections problem after PIX upgrade to 8.0
bahaaothman
after upgrading from version 7.2 to 8.0(4), clients couldn't connect to the database through the firewall using Toad software but they can connect using SQL.
I checked the firewall and found some dropped packets in inspect sqlnet.
I disabled sqlnet inspection and the clients can connect.
The next day some clients reported that the database applications isn't working, I checked the firewall and found some denied connections on ports other than 1521
What is the problem, Please help
abinjola
There are known issues with SQLNET traffic traversing through the firewall on 8.0.4, one of the known issue CSCsu44598
Upgrade to 8.0.4.8
Please send me more details about these issues as I think 8.0(4)3 is the latest version
Nobody answered me
How do I know the latest versoin and where can I find information about this bug??
Here is details, if you have cco access to download software see interim releases to get the codes , if not there you probably need to open a TAC case to get codes not shown in interim area. However, you have coupled of workaround seen down bellow , the quickest workaround is to disable sql inspection in your global policy to atleast get you up and running with sql.
CSCsu44598 Bug Details
SQLNet inspection closes flow
Symptom:
Issue with SQLNet access
Conditions:
Issue is seen with ASA 8.0(4) with SQLNet inspection enabled. Inspection
denies CLOB data field size of greater than 4KB. The following log messages
are seen on the ASA:
%ASA-6-302014: Teardown TCP connection...Flow closed by inspection
When enabling 'debug sqlnet 255 ', you may also see the following debug message:
SQLNet: multiple TNS frames in one packet!
Workarounds:
1) Disable SQLNet inspection
2) Downgrade to a version prior to 8.0.3.33
Further Problem Description:
This bug was introduced due to the integration of CSCsr27940 in version
8.0.3.33 and 7.2.4.15. Versions prior to these release should not be affected.
Status
Fixed
(Resolved)
Severity
3 - moderate
Product
Cisco ASA 5500 Series Adaptive Security Appliances
Technology
1st Found-In
8.0(4)
Fixed-In
8.1(2.1)
8.2(0.161)
8.0(4.7)
7.2(4.17)
8.1(2.2)
Jorge Rodriguez
