SSH Issue with ASA 5505 running 8.3(2)
aubreyrhame
I'm replacing a new ASA 5505 due to a corrupted flash.  On the original unit, I had the ability to SSH into the device using TeraTerm with no problems.
While configuring the new device, I entered the following commands to enable SSH into the unit:
crypto key generate rsa modulus 1024
write mem
ssh 192.168.0.0 255.255.255.0 inside
ssh timeout 30
However, now, using TeraTerm, anytime I attempt to SSH into the unit, I get the following message:
All the encryption algorithms that this program and the server both understand have been disabled.  To communicate with this server, you will have to enable some more ciphers in the TTSSH Setup dialog box when you run Tera Term again.  This connection will now close.
please help.
Aubrey
5 Replies 5
mvsheik123
Level 7
Level 7
Have you tried clearing the ssh key and recreating the same?
Thx
MS
Yes, I have
lcaruso
Level 6
Level 6
re: ssh 192.168.0.0 255.255.255.0 inside
did you intend to use subnet zero?
if not, try 192.168.0.0 255.255.0.0
maybe that will make a difference
then make sure whatever you use on the ASA is exactly the same on the SSH client
Yes, this way anyone on the 192.168.0.1-192.168.0.254 subnet could ssh into the ASA device
it was worth a shot
if there is anyway you can view the ASA log to see what messages lurk there, I'd try that.
having a console connection while the ssh attempt is made to view the log and/or debug can be helpful
