Static route on inside interface of ASA does'nt work
asirajahmed28
I have three Subnets connected through a router in my LAN (Inside interface)
route Outside 0.0.0.0 0.0.0.0 1x.1az.az.161 1
route Inside 192.168.2.0 255.255.255.0 192.168.0.254 1
route Inside 192.168.16.0 255.255.255.0 192.168.0.254 1
route Inside 192.168.55.0 255.255.255.0 192.168.0.254 1
I can reach to the IP's 192.168.2.0/24 and the other two subnets from the ASA
But not through the PC on my LAN tried with ACL etc.
Am I missing something here ?
16 Replies 16
If you do not know,then please do not post all this thing which is not useful.  Do not confuse the persons who are trying to learn something. Those code are not useful as I tried on real scenario.
jroy777
Would this be a legitimate Nat statement on the ASA if I have a router in parallel with the ASA on the same inside subnet? (router also has an IP from "outside" subnet). It is in parallel to take VPN load off ASA.
nat (inside,inside) 1 source static inside-AMZ-VPN inside-AMZ-VPN destination static obj-amzn-10.24.0.0s13 obj-amzn-10.24.0.0s13 no-proxy-arp description NONAT
I can trace from ASA and it routes to router. If I trace from a host on inside, it goes to ASA which is Default GW for all host on inside network but then continue to outside interface and out.
