tacacs+ authentication problem
Colin Higgins
Level 7
Level 7
I have a ASA services module running in a 6500
I have configured a firewalled vlan for management (172.25.50.x) and applied a permissive access list inbound and outbound to it
I added the ASA as a client on the Cisco ACS (tacacs) server and double-checked the key
The ACS server can ping the firewall, and the firewall can ping the ACS server.
I've issued the following commands on the ASA
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server TACACS+ (mgmt) host 172.25.32.80 <key> timeout 5
aaa authentication ssh console TACACS+
username <user> password <password> priv 15
when I ssh to the ASA, the firewall is not using tacacs+. It is using the local database instead.
There is no activity i the ACS logs
So the firewall isn't even attempting to use tacacs+
Is there something I am missing here?
Julio Carvajal
Hello Colin,
Can you share
show run ssh
show run aaa
show run aaa-server
test aaa-server  TACACS+
172.25.32.80
username whatever
password whatever
And provide the outputs
For more information about Core and Security Networking follow my website at http://laguiadelnetworking.com
Any question contact me at [email protected]
Cheers,
Julio Carvajal Segura
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Julio Carvajal
Hello Colin,
Can you share
show run ssh
show run aaa
show run aaa-server
172.25.32.80
username whatever
password whatever
Cheers,
Julio Carvajal
When I did the test aaa-server it worked, and I realized I forgot to add
aaa authentication enable console TACACS+
to the ASA
this made everything work correctly. Thanks for your help!
Hello Colin,
So it was a problem with the enable password and not with the SSH authentication
Glad to know its up and running now
Cheers,
Julio Carvajal
