Talos Connectivity Problem
Ditter
Level 8
Level 8
Hi to all ,
i am getting many messages as the following:
Severity: critical
Module: Talos Communication
Description: 3 modules failed:
  • * URLDB- Failed to retrieve beaker inventory
  • * LSP- Failed to retrieve beaker inventory
My subscription is active (it expires in 2026).
Any ideas about why is this happening?   Is it a problem that has to do with Talos?
Please note that this is the first time i get this message.
The only change i did some days ago was to change the "Cached URLs Expire" which was set to never and i changed it to "week" but i do not think that my issue has something to do with it.
Any ideas,
Ditter.
94 Replies 94
@Artezys79 make sure you have the "Customer Success Network" integration enabled under Cloud Services. I upgraded several FMCs in the past day and it fixed the issue for the ones that were manifesting it.
With next upgrade to 7.6.2 still having issues with certificate expired in March 2025 and Talos alarms keep appearing with all services enabled.
Chess Norris
Level 9
Level 9
Did the upgrade at a customer site today. After the upgrade I noticed another alert - "Smart Agent communication error with Smart Licensing Cloud".
 Customer Success Network integration was already enabled. Anyone else got the same error?
/Chess
Edit. Seems like this alert comes a bit randomly. No more alerts on the last 3 checks. Will keep monitor it for a while.
Ditter
Level 8
Level 8
This TALOS thing drives most of us crazy.
I upgraded to FMC 7.7.0.91 (from 7.6) and the problems with all these messages came back on (every 5 minutes but not all day , some specific time periods) .
Health Monitor Alert from fmc
Time: Thu Jul 3 06:35:08 UTC 2025 UTC
Severity: critical
Description: 1 modules failed:
As we speak no messages such as these,   are coming in but no warranty that they will not restart ... 😞
And currenty i run VDB version: build 408 ( 2025-04-29 08:56:28 )
Just for Information.
Ditter
   - @Ditter            FYI :   (corrections)
                                      https://www.cisco.com/c/en/us/support/docs/field-notices/742/fn74284.html
                                      https://www.cisco.com/c/en/us/support/docs/field-notices/742/fn74272.html
   M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
After I had the same issue even upgrading a customers FMC to the suposed fixed version 7.6.1, I opened a TAC case. TAC then told me to run the following command from expert mode - start_beaker_process.sh beaker3
It's now been two weeks with any alerts. Not sure what's the difference between this script and restarting the breaker process (that I also tried before but that only helped temporary). Might be worth giving this command a shoot for those still struggling with this alert.
/Chess
Ι recall to have done this stop/start process in the past but the messages kept randomly coming back. I will give it a new try. Thanks.
Running this "start_beaker_process.sh beaker3" resolved my issue.
The certificate "openssl x509 -text -in /var/sf/beaker3/securefirewall-dev-prod-01_prod.pem" is now in date and I am able to get URL Filtering updates under the Cloud Integrations section. I am running FMC 7.7.
I thought that command resolved my issue as well. However, we just received the same alert again.  The FMC has been running fine without this alerts for almost 3 month. I will open a new TAC case and hope they can provide a permanent fix this time.
You might need to update the LSP. and reboot FMC if needed.
Ditter
Level 8
Level 8
Me too, the last days i get many of these messages every 5 minutes , not the whole day but occasionally, but when it starts i keep getting these failures every 5 minutes.
Issuing the commands :
pmtool restartbyid talosAgent
pmtool restartbyid beaker3
did not help.
I am running 7.7.10-3089.
Ditter
Replace7073
Frequent Visitor
Frequent Visitor
We had this same issue in the past but it went away after a specific VDB/SRU update.
We received some of these alerts yesterday after hours but today they have persisted every 5 minutes. I ended up opening a new TAC case referencing our original one.
Did you get an answer from TAC?
TAC told me we are hitting this bug https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwq37578
No news about a permanent fix. I will ask TAC if they can escalate to BU.
/Chess
Loebmann
Frequent Visitor
Frequent Visitor
I no longer have any problems with the LSP update with 7.7.10, but I am not using any cloud services.
I found the following bug:
“FMC cannot fully use licensed features requiring Talos Cloud Services when using air-gapped or evaluation licensing - CSCwr23982”
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwr23982
This affects 7.6.1/7.6.2 and 7.7.10.
The certificate under “openssl x509 -text -in /var/sf/beaker3/securefirewall-dev-prod-01_prod.pem” is currently valid until October 14, 2025, at 4:14 p.m. Let's see if problems arise after that or if it is updated properly.
