Talos Connectivity Problem
Ditter
Level 8
Level 8
Hi to all ,
i am getting many messages as the following:
Severity: critical
Module: Talos Communication
Description: 3 modules failed:
  • * URLDB- Failed to retrieve beaker inventory
  • * LSP- Failed to retrieve beaker inventory
My subscription is active (it expires in 2026).
Any ideas about why is this happening?   Is it a problem that has to do with Talos?
Please note that this is the first time i get this message.
The only change i did some days ago was to change the "Cached URLs Expire" which was set to never and i changed it to "week" but i do not think that my issue has something to do with it.
Any ideas,
Ditter.
79 Replies 79
Apologies i upgrade FMC to 6.2 recommended
We started getting the Talos LSP health alert this morning. Restarting the talosAgent and beaker3 services seems to have fixed it.
Thanks!
We havent had the problem for a while. Running 7.7 was ok. After uograding to 7.7.10 and 7.7.10.1 the problem is back. Dont understand why at all!
Please rate as helpful, if that would be the case. Thanx
I have this issue as well this AM.  Attempting solution described in CSCwo63951 (above)
Solution worked.  TY
Getting "Cisco Support Diagnostics Configuration failure" on the FTD's connected to FMC's after restarting, any tips ?
Hi Jon,
We had those errors here too, but dont seem related to talos connectivity problem. We've recently test log sending to SCC and we had some options checked on Integrations / Cisco security cloud to "send events to cloud" but the Cisco Security Cloud was disabled. We unchecked the options to send logs and errors disappeared.
Did a disconnect - reconnect to cloud and everything back to normal.
So, is this related and/or limited to 7.7.0-91? I see there is now a disclaimer "If you are already running 7.7.0-89. Do not upgrade/install the newly posted image (7.7.0-91). Reach out to Cisco TAC for a workaround." at the software download section.
@HQuest that is unrelated and due to a separate issue related to NAT in site-site VPNs.
Ditter
Level 8
Level 8
@BACANEL @Marvin Rhoads Thanks both,  i restarted only the two processes mentioned by Bacanel.  I did not restart (fireamp & CloudAgent but the warnings messages stopped by restarting the first two processes (talosagent and beaker3):
Ditter
JF Anctil
Visitor
FYI :
VDB 406 is not released yet but it worked with this GeoDB database update.
Update : The script is running only on the active FMC. My secondary FMC has the new GeoDB update but has not run the script to renew the certificate.
Update2 : Same for VDB Update. The script is not running on secondary FMC so the certificate is still not renewed.
Loebmann
Frequent Visitor
Frequent Visitor
Hello everyone,
 I have installed the GeoDB and VDB 406 and restarted the vFMC, but the error message remains the same. Does anyone else have this?
Ditter
Level 8
Level 8
Still the same error with me although it seemed to have stopped. I have already upgraded to VDB 406 but i still get :
Health Monitor Alert from fmc
Time: Sat Apr 12 11:05:31 UTC 2025 UTC
Severity: critical
Description: 1 modules failed:
I haven't rebooted the FMC. Doo in need to reboot it ?
Ditter
 - @Ditter             FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwo63951
    M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
