TCP reset does not work.
mia.miraples
I am trying to test the TCP reset for the IDS-4250-SX, but it seems that it does no work. I have tried lots of signature that pertains to TCP, i dont see any TCP reset packets from the sensor. Anybody have an idea if some of TCP signatures really does not send TCP reset?? What are the TCP signature that can send TCP reset.
I issued the "TCPDUMP" command on the IDS to verify for TCP reset packet.
adiwakar
This link shows how to configure and then test TCP Reset using the signature STRING.TCP.
just enter the command testattack from your routing device
http://www.cisco.com/en/US/products/hw/vpndevc/ps4077/products_configuration_example09186a00801c0e11.shtml
