Telnet from Outside switch to DMZ switch connected to ASA.
mahesh18
Level 6
Level 6
Hi all,
I have switch b connected to ASA  with fas0/40 under vlan 40.
ASA connection to this switch is under Vlan 3 which is DMZ.
OSPF is running between OSPF and DMZ switch.
I was trying to telnet from Outside interface switch to DMZ  switch which goes through the ASA.
My question is is it possible from Outside Switch to ping the DMZ switch or telnet to it as connection has to pass by ASA ?
Mahesh
2 Accepted Solutions
Julio Carvajal
Yes, it is possible.
You just need to allow that traffic over the ASA.
Also if NAT is required then perform a biderectional nat from DMZ to outside,
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hello Mahesh,
Yes, as I said on my previous post
access-list outside_in permit tcp host outside_switch_ip host dmz_switch_ip eq 23
access-group outside_in in interface outside
If you want to check if everything is properly setup for that connection to work across the ASA do the following:
packet-tracer input outside tcp outside_ip_switch 1025 dmz_switch_ip 23
Remember to rate all of the helpful posts
Julio
Julio Carvajal
5 Replies 5
Julio Carvajal
Julio
Julio Carvajal
Hi julio,
Currently i am able to telnet from DMZ  switch to Outside Switch through ASA.
But not from outside switch to DMZ  switch.
Right now no Nat is running on ASA.
Outside Switch has route to DMZ  switch by ASA.
Should i allow telnet ACL  on ASA  outside interface to make this work?
Mahesh
Hello Mahesh,
Julio
Julio Carvajal
Hi Julio,
It worked great.
Also i ran the packet tracer command before and after the i applied ACL.
After applying ACL  it was all Allow .
Best regards
Mahesh
That is great,
Julio Carvajal
