10-27-2012 03:58 PM - edited 03-11-2019 05:15 PM
Hi all,
I have switch b connected to ASA with fas0/40 under vlan 40.
ASA connection to this switch is under Vlan 3 which is DMZ.
OSPF is running between OSPF and DMZ switch.
I was trying to telnet from Outside interface switch to DMZ switch which goes through the ASA.
My question is is it possible from Outside Switch to ping the DMZ switch or telnet to it as connection has to pass by ASA ?
Mahesh
Solved! Go to Solution.
10-27-2012 04:00 PM
Yes, it is possible.
You just need to allow that traffic over the ASA.
Also if NAT is required then perform a biderectional nat from DMZ to outside,
Julio
10-27-2012 04:30 PM
Hello Mahesh,
Yes, as I said on my previous post
access-list outside_in permit tcp host outside_switch_ip host dmz_switch_ip eq 23
access-group outside_in in interface outside
If you want to check if everything is properly setup for that connection to work across the ASA do the following:
packet-tracer input outside tcp outside_ip_switch 1025 dmz_switch_ip 23
Remember to rate all of the helpful posts
Julio
10-27-2012 04:00 PM
Julio
10-27-2012 04:27 PM
Hi julio,
Currently i am able to telnet from DMZ switch to Outside Switch through ASA.
But not from outside switch to DMZ switch.
Right now no Nat is running on ASA.
Outside Switch has route to DMZ switch by ASA.
Should i allow telnet ACL on ASA outside interface to make this work?
Mahesh
10-27-2012 04:30 PM
Hello Mahesh,
Julio
10-27-2012 04:45 PM
Hi Julio,
It worked great.
Also i ran the packet tracer command before and after the i applied ACL.
After applying ACL it was all Allow .
Best regards
Mahesh
10-27-2012 05:02 PM
That is great,
