Terminate SIP Connection on ASA 5505... Is it possible?
Luis Sanchez
Hello everyone,
I have a SIP trunk in my Florida office connected to a Cisco 2851 ISR. I'm using Unified Communications Manager 8.0 and life is great.
We just opened a new office in Spain and now the fun begins.  We created a site-to-site VPN tunnel using ASA 5510 in Florida and ASA 5505 in Spain. We can register IP Commuicator phones in Spain but when they make calls it shows up as a Florida call. We need it to show up as a Spain call.
We are thinking to get a SIP trunk into the Spain office but I only have a ASA 5505 over there. Can I terminate a SIP connection to it? Is this the best option? If not, what is the recommened setup?  Thanks!
The payload option commonly used to perform NAT, between devices on overlapping networks that share the same IP address. For example, when an outside device sends a DNS query to 172.16.5.13, in order to reach an inside device 172.16.2.13, the local address inside the payload of the DNS reply is translated to a global address according to the relevant NAT rule.
Perhaps, the Cisco's DNS Doctoring method would work fine for you.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807968c8.shtml
Ram
Warm regards,
Ramraj Sivagnanam Sivajanam
