timeout problem with asa5520 v7.2
julxu
Level 7
Level 7
Greating
My servers behind asa5520 inside interface, seems have problem with timeout.
all the sessions from internet to inside servers seems be cut off if user keep idle more than 30 mins.
however, the subnet which I did configure the box has not such problems.
Could anyone advice me if the ASA5520 can control the session timeout?
Any comments will be apprecaited
Thanks in advice
guibarati
Level 8
Level 8
Yes, the ASA control the session timeout, otherwise if a host in the internet just leave the connection (without an RST or FIN) it would be endless active in ASA.
You must use a feature in ASA that veryfies the connection by sending packets to both hosts with spoofed information, to see if the respond to that connection.
in the link:
http://www.cisco.com/en/US/docs/security/asa/asa72/command/reference/s1_72.html
look for "DCD"
you should use "timeout tcp" option, whith a timeout lower then 30 minutes.
guibarati
Level 8
Level 8
in the link:
look for "DCD"
