Traffic is not passing through IDSM-2 module in 6509
I have some similar type of issue while configuring the IDSM-2 in inline mode. My scenario is that I want to deploy IDSM-2 inline mode between two vlans (vlan 20 and vlan 30). when the traffic going from vlan 20 to vlan 30 and vice versa then i shold be pass thgough the IDSM-2. I have configured the device both (6500 and IDSM-2) module according to the cisco configuration guide but unfortunately it is not working. I am not getting any logs in the IDSM-2 even action configured on IDSM-2.
For your information and review, I am attaching all the config with IDM snapshots.
config on 6509 switch:
intrusion-detection module 1 management-port access-vlan 90
intrusion-detection module 1 data-port 1 access-vlan 20
intrusion-detection module 1 data-port 2 access-vlan 30
int vlan 20
ip add 10.20.1.1 255.255.255.0
int vlan 30
ip add 10.30.1.1 255.255.255.0
int vlan 90
ip add 10.90.1.1 255.255.255.0
Kindly advise.
thanks,
Aman
5 Accepted Solutions
Roman Rodichev
Level 7
Level 7
IDSM is a bridging device
You have configured a different IP subnet on two layer 3 VLAN interfaces. You need to have the same IP subnet on both VLANs (inside IDSM and outside IDSM).
Normally, you will have one Layer 3 VLAN for the first VLAN, and the second VLAN will not have any Layer 3 VLAN interfaces, and that's where you put your servers. The traffic would flow as such:
Server 10.20.1.2 (default gateway 10.20.1.1) --- VLAN 30 --- IDSM --- VLAN 20 --- SVI VLAN 20 10.20.1.1
If you need to pass traffic through IDSM between two L3 SVIs, then you have to put L3 SVIs into two separate VRFs, and both SVIs must be in the same IP subnet.
I need to know what traffic you want to inspect. Are you inspecting traffic to/from a group of servers, what VLAN do these servers belong to? user to Internet traffic, what VLAN do the users belong to?
ok in this case, create new VLAN 21, remove VLAN 20 SVI and put the IP address on VLAN 21 SVI instead. Configure IDSM to bridge from VLAN 20 to VLAN 21. The servers will be in VLAN 20, no hosts will be in VLAN 21 (just SVI and one side of IDSM).
vlan 21
vlan 20
intrusion-detection module 1 data-port 2 access-vlan 21
int vlan 21
and you are probably better of trunking through the IDSM, this way you can add more VLANs to inspect in the future. Also note that when you trunk through IDSM both VLANs must be on the same data port.
intrusion-detection module 1 data-port 1 trunk allowed-vlan 20
intrusion-detection module 1 data-port 1 trunk allowed-vlan 21
No. User VLANs don't need to touch IDSM. The traffic flow is:
User in VLAN 40 - VLAN 40 - VLAN 40 L3 SVI - VLAN 21 L3 SVI - VLAN 21 - IDSM - VLAN 20 - Server in VLAN 20
That's correct, you won't be using data port 2.
12 Replies 12
Roman Rodichev
Level 7
Level 7
thanks for the prompt response, can you please write the config command that need to be done on 6500 switch, including intrusion-detection and SVI commands.
thanks,
Aman
Actually, I have a server farm vlan (vlan 20). I need this vlan will be inspect when the users from different vlans, for example (vlan 30,40,50) want to access these servers.
Aman
vlan 21
vlan 20
int vlan 21
Thanks a lot dear friend I got the answer !!!
Nice talking you. Can I contact you if  i will get any issue during deployment?
I have noted your email address from your profile. Kindly confirm.
Aman
that's fine, but you'll probably get an answer here on CSC faster
You mean to say that, if I have users in diff vlan (like, vlan 40,45 abd 50-60) to access the servers in vlan 20 so the config wil be:
intrusion-detection module 1 data-port 2 trunk allowed-vlan 40,45,50-60
thanks,
Aman
its mean that the config will remain same, like:
I will not configure data-port 2 for any purpose. Am I rite?
Aman
Hi Roman,
Thanks for your all responses !!!
I have one more query with you now,
I have only one Layer 3 switch in which Hosts and server are connected. Now I want to connect IPS applicance 4200 series in one port of switch and want to configure inline vlan pair mode.
Case # 01:
If both Hosts and servers are in the same ip subnet.
Case # 02
If Hosts and Server are in the diff subnets
Kindly advise the connectivity and config that how can I achieve these targets?
Aman
