Traffic shaping per users , ip ,application using ASA
acharyr123
Level 3
Level 3
I hava Cisco ASA 5520 with AIP-SSM module. I would like to have the below features with ASA installed in Transparent mode.
1. Traffic shapping per user
2.  Traffic shapping per IP subnet
3.  Traffic shapping per Application
Is it possible with ASA installed in Transparent mode??
9 Replies 9
padatta
Unfortunately traffic shaping is not supported in transparent mode.
Here is the reference.
http://www.cisco.com/en/US/partner/docs/security/asa/asa82/configuration/guide/conns_qos.html#wp1111709
Paps
Thanks for your prompt support....
Whether this feature is supported in Routed mode??
Partha
Hello Partha,
The feature is supported in Routed mode.
Please mark the post answered for others to refer in future.
Cheers,
Chirag
I have an ASA 5520 in routed mode and would like to shape based on IP address. Can anyone share any configuration examples for this?
Trent
Hi, See below a QoS config example for an ASA
https://supportforums.cisco.com/docs/DOC-1230
Don't forget to rate posts that are helpful.
Thanks for the link. If I apply a QoS policy, be it shaping or policing, does that affect EACH INDIVIDUAL CONNECTION (ip address) on the interface? Or does it QoS the ENTIRE interface? I am looking limit bandwitdh on a per connection/ip address basis.
Trent
Daryl,
It rate limits the connection based on ip address for traffic going from that particular interface only. It woudl not rate limit any other IP address not specified in the ACL for QoS that we have created. We specify the interface just to notify the ingress and egress point of the traffic.
Varun
Varun Rao
Just to clarify, all I would need to do is set up policing and it will be done on a per IP basis (kinda new at this ASA)? Also, can shaping be done in the ASDM or can I only police?
Trent
FOr shaping you can follow this doc:
http://www.cisco.com/en/US/partner/docs/security/asdm/6_2/user/guide/qos.html#wp1065249
Plicing would b done as per IP basis, through ACL
Varun
Varun Rao
