Trying to browse to my management1/1 portal and not showing
devondalton59
Firepower 1010 v6.6 When I try to browse to management ip I assigned it worked for one day and then the next it did not work no more. So I factory reset it follow the Cisco white pages and now I can’t get back in the firewall now. When type /show interface ip brief there is no ip assigned can I get some help
@devondalton59 on FTD CLI, to determine the management interface IP address use the command "show network".
To configure the management interface use the command "configure network ipv4 manual <ip addr> <mask> <gw>"
