Unable to connect LAN to LAN between IPSEC VPN - both ASA devices
habeebuddin786
Hello Folks,
I am trying to bring up the connectivity between LAN to LAN over IPSEC VPN tunnel and we are using both devices as ASA. Dallas ASA is using 8.2(2) version and SJC ASA is using 8.2(1) version.
I tried every possibility to test the connection but encrypt packets are not seen on the SJC VPN side and decrypt packet are not seen on the dallas side. However the packet tracer from one phase to another is allowing everything and nothing is blocking. I checked the routes as well on the FWSM behind the VPN on both sides and looks good and routes are pointing to VPNs. Both sides are seen that the packet are receiving from internal. Attached are the statistics of packet-tracer and ipsec sa of both VPNs for your reference.
Below are the recommendations of Cisco and followed to fix it. Suspecting the bug in the code of SJC-VPN-ASA as it is using the version as 8.2(1) and dallas one is using as 8.2(2). But would like to confirm if anything i missed to try.
Following are the things I tried so far:
1) reset the phase 1
2) reset the phase 2
3) clear xlate
4) packet-tracert input inside icmp src-ip(dallas/SJC) and dst-ip (SJC/Dallas) detailed (every phase shows ALLOW)
Attached are the configs of both the VPN.
Approciate your time and help in this to fix the issue.
Thank you.
-Ahmed
9 Replies 9
Jennifer Halim
On the Dallas end, add the following:
management-access prod-vpn-inside
Try to ping from the ASA:
From SJC: ping inside 10.120.188.3
From Dallas: ping prod-vpn-inside 10.126.188.5
If you are able to ping and seeing encrypts and decrypts, that means nothing wrong with the ASA config.
nkarthikeyan
Level 7
Level 7
Hi habbeb,
I have checked your configuration and found few things in your configuration. In dallas end you do not have the no nat configured. i mean the NAT command is missing. Also please check on the NAT traversal feature.... if you are getting logs for NAT reverse path denies the traffic then make changes on the NAT traversal...
Hope this will make your VPN up and running.
Try establising the connection in this way also from your inside segment switch to generate the intersting traffic.
telnet /source-interface vlan
here are my findings on both the firewalls.
Please do rate if the given information helps.
SJC End
interface GigabitEthernet0/0
speed 1000
duplex full
nameif outside
security-level 0
ip address 205.140.203.10 255.255.255.248
access-list inside_nat0_outbound extended permit ip 10.126.0.0 255.255.0.0 10.120.0.0 255.255.0.0
access-list SJC-DAL-prod-vpn extended permit ip 10.126.0.0 255.255.0.0 10.120.0.0 255.255.0.0
crypto map outside_map 30 match address SJC-DAL-prod-vpn
crypto map outside_map 30 set peer 205.216.36.134
crypto map outside_map 30 set transform-set ESP-AES-256-SHA
crypto map outside_map 30 set security-association lifetime seconds 28800
crypto map outside_map 30 set security-association lifetime kilobytes 4608000
crypto map outside_map interface outside
crypto isakmp identity address
crypto isakmp enable outside
tunnel-group 205.216.36.134 type ipsec-l2l
tunnel-group 205.216.36.134 ipsec-attributes
pre-shared-key *
crypto isakmp policy 1
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 5
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 10
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp policy 30
encryption 3des
hash md5
group 1
lifetime 86400
crypto isakmp nat-traversal 30
nat (inside) 0 access-list inside_nat0_outbound
Dallas End
nameif prod-vpn-outside
security-level 0
ip address 205.216.36.134 255.255.255.128 standby 205.216.36.135
access-list nonat extended permit ip 10.120.0.0 255.255.0.0 10.126.0.0 255.255.0.0
access-list Dal-SJC-prod-vpn extended permit ip 10.120.0.0 255.255.0.0 10.126.0.0 255.255.0.0
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto map outside-map 10 match address Dal-SJC-prod-vpn
crypto map outside-map 10 set peer 205.140.203.10
crypto map outside-map 10 set transform-set ESP-AES-256-SHA
crypto map outside-map 10 set security-association lifetime seconds 28800
crypto map outside-map 10 set security-association lifetime kilobytes 4608000
crypto isakmp enable prod-vpn-outside
encryption aes-256
hash sha
group 5
lifetime 86400
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 100
encryption 3des
hash sha
group 2
lifetime 86400
no crypto isakmp nat-traversal
tunnel-group 205.140.203.10 type ipsec-l2l
tunnel-group 205.140.203.10 ipsec-attributes
pre-shared-key *****
By
Karthik
Hi Bro
Shown below are the configuration changes that you'll need to cut and paste into your respective Firewalls;
Dallas FW
config t
nat (prod-vpn-inside) 0 access-list nonat
access-list outside permit icmp any any echo
access-list outside permit icmp any any echo-reply
access-group outside-in in interface prod-vpn-outside
SJC FW
config t
crypto isakmp policy 40
encryption aes-256
hash sha
group 2
lifetime 86400
In both FW
config t
sysopt connection permit-vpn
clear threat-detection shun
crypto isakmp keepalive 10
Once you've done that, issue the command clear crypto isakmp sa and clear crypto ipsec sa, and try to access both sides e.g. PING. If it doesn't work, paste back here the latest config on both the Firewalls.
Warm regards,
Ramraj Sivagnanam Sivajanam
Hello brothers,
Thank you very much for your response and helping me in this one. I tried the steps recommended by Ramraj but no luck. No changes in the behaviour.  As recommeded I am attaching the latest config of both side Firewalls with IPSEC sa output and Packet tracer.
Please suggest next plan of action.
-Ahmed
Hi Ahmed,
Please find the troubleshooting info for your issue. Please try with the steps provided in the last.
You need to check crypto acl matches @ both the ends. NAT 0 exempt traffic is correct on both the ends. Routing is find on both the ends.
Also try enabling the sysopt permit connection-vpn / sysopt connection permit-vpn
Unable to Pass Traffic Across VPN Tunnel
Problem
You are unable to pass traffic across a VPN tunnel.
Solution
This issue occurs due to the problem described in Cisco bug ID CSCtb53186 (registered customers only) . In order to resolve this issue, reload the ASA. Refer to the bug for more information.
This issue might also occur when the ESP packets are blocked. In order to resolve this issue, reconfiguring the VPN tunnel.
This issue might occur when data is not encrypted, but only decrypted over the VPN tunnel as shown in this output:
ASA# sh crypto ipsec sa peer x.x.x.x
peer address: y.y.y.y
    Crypto map tag: IPSec_map, seq num: 37, local addr: x.x.x.x
      access-list test permit ip host xx.xx.xx.xx host yy.yy.yy.yy
      local ident (addr/mask/prot/port): (xx.xx.xx.xx/255.255.255.255/0/0)
      remote ident (addr/mask/prot/port): (yy.yy.yy.yy/255.255.255.255/0/0)
      current_peer: y.y.y.y
      #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
      #pkts decaps: 393, #pkts decrypt: 393, #pkts verify: 393
      #pkts compressed: 0, #pkts decompressed: 0
      #pkts not compressed: 0, #pkts comp failed: 0, #pkts decomp failed: 0
      #pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
      #PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
      #send errors: 0, #recv errors: 0
In order to resolve this issue, check the following:
  1. If the crypto access-lists match with the remote site, and that NAT 0 access-lists are correct.
  2. If routing is correct and traffic does hit outside interface passing  through inside. The sample output shows that decryption is done, but  encryption does not occur.
  3. If the sysopt permit connection-vpn command has been configured on the ASA. If not configured, configure  this command because it allows the ASA to exempt the encrypted/VPN  traffic from interface ACL checking.
Please do rate for the helpful posts.
By
Karthik
Hi Bro
Please paste your latest Firewall config here (both units). I want to verify your config.
Worst case, we may need to add this line in PROD-VPN-ASA Firewall to solve the issue;
route outside 10.120.0.0 255.255.0.0 205.140.203.1
Warm regards,
Sorry I though I pasted the latest config.
Here are the lates config of both the firewalls.
-Ahmed
Seems this is relate to BUG as per the following link:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtb53186
SJC-VPN (ASA5520) is running version 8.2(1) and this bug is found first in 8.2(1) and as per the IT deployment team this tunnel is broken 6 months back and since then no network engineer is worked  on it as the earlier network engineer left the job. I have recently joined and this task is priority to me.
Also can I have steps or the link in which shows upgrade of software from 8.2(1) to 8.2(4). Much appreciate your time and effort in this to fix this one.
Below is the software version of SJC VPN:
Cisco Adaptive Security Appliance Software Version 8.2(1)
Device Manager Version 6.2(1)
Compiled on Tue 05-May-09 22:45 by builders
System image file is "disk0:/asa821-k8.bin"
Config file at boot was "startup-config"
PROD-VPN-ASA up 2 years 342 days
Hardware:   ASA5520, 512 MB RAM, CPU Pentium 4 Celeron 2000 MHz
Internal ATA Compact Flash, 256MB
Slot 1: ATA Compact Flash, 128MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
                             Boot microcode   : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.04
0: Ext: GigabitEthernet0/0  : address is 001e.f760.a2a4, irq 9
1: Ext: GigabitEthernet0/1  : address is 001e.f760.a2a5, irq 9
2: Ext: GigabitEthernet0/2  : address is 001e.f760.a2a6, irq 9
3: Ext: GigabitEthernet0/3  : address is 001e.f760.a2a7, irq 9
4: Ext: Management0/0       : address is 001e.f760.a2a8, irq 11
5: Int: Not used            : irq 11
6: Int: Not used            : irq 5
Licensed features for this platform:
Maximum Physical Interfaces  : Unlimited
Maximum VLANs                : 150
Inside Hosts                 : Unlimited
Failover                     : Active/Active
VPN-DES                      : Enabled
VPN-3DES-AES                 : Enabled
Security Contexts            : 2
GTP/GPRS                     : Disabled
SSL VPN Peers                : 2
Total VPN Peers              : 750
Shared License               : Disabled
AnyConnect for Mobile        : Disabled
AnyConnect for Linksys phone : Disabled
AnyConnect Essentials        : Disabled
Advanced Endpoint Assessment : Disabled
UC Phone Proxy Sessions      : 2
Total UC Proxy Sessions      : 2
Botnet Traffic Filter        : Disabled
This platform has an ASA 5520 VPN Plus license.
Serial Number: JMX1209L1QH
Running Activation Key: 0x0b13d651 0x10bee714 0x24326da4 0xbc10ccfc 0x4201a5aa
Configuration register is 0x10001
Configuration last modified by enable_15 at 23:36:09.498 GMT Tue Aug 28 2012
Hi Bro
Frankly, I doubt this is a bug related issue. However, you could refer to this Cisco URL http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008067e9f9.shtml#maintask1, in particular the  Ugrade a Software Image and ASDM Image using CLI section, if you want to upgrade both sides of the Firewall to version 8.2.4.
By the way, can you kindly make the configurations changes as shown below;
Dallas FW
access-list outside-in line 1 permit icmp any any
access-list outside-in extended deny ip any any
no crypto isakmp ipsec-over-tcp port 10000
SJC FW
access-list outside_access_in line 1 permit icmp any any
Warm regards,
