Unable to move from interface to subinterface using contextmode on 5515-x
thomas.stern
Community Member
Long time reader, first time poster
I am moving from using an ordinary interface to subinterfaces in order to move two contexts to same physical interface. However I cannot get the config to work.
in system context:
interface GigabitEthernet0/3
interface GigabitEthernet0/3.1
 vlan 310
interface GigabitEthernet0/3.2
 vlan 320
context context1
  allocate-interface GigabitEthernet0/0 B_outside
  allocate-interface GigabitEthernet0/3.1 B_inside
  config-url disk0:/context1.cfg
context context2
  allocate-interface GigabitEthernet0/0 C_outside
  allocate-interface GigabitEthernet0/3.2 C_inside
  config-url disk0:/context2.cfg
in context1:
interface B_inside
 nameif inside
 security-level 100
 ip address 192.168.11.1 255.255.255.0 standby 192.168.11.250
all other conf is the same as before (I readded the nats that were removed when I went to subinterfaces) and previously I could just "ping 192.168.11.5" from context1 , now I cannot. Nor do ssh tunnnels or https rules work)
Do I need to setup a switchport or something inside the context to vlan 310 , I am at a loss
ciscoasa/context1# show interface
Interface B_outside "outside", is up, line protocol is up
        MAC address **, MTU 1500
        IP address **, subnet mask 255.255.255.248
  Traffic Statistics for "outside":
        4203345 packets input, 2260290490 bytes
        2849981 packets output, 1589294400 bytes
        32004 packets dropped
Interface B_inside "inside", is up, line protocol is up
        IP address 192.168.11.1, subnet mask 255.255.255.0
  Traffic Statistics for "inside":
        0 packets input, 0 bytes
        139 packets output, 3892 bytes
        0 packets dropped
/thomas
Akshay Rastogi
Hi Thomas,
First thing is , add 'mac-address auto' in system configuration mode.
Also check if you have made the switchport as trunk on the switch and allowed vlan 310 in that trunk.
Akshay Rastogi
Jon Marshall
Thomas
Sorry to ask the obvious but have you made the port on your switch a trunk port ie. the port the ASA interface connects to.
Jon
Akshay Rastogi
Hi Thomas,
Akshay Rastogi
thomas.stern
Community Member
Thanks for the info, I didn't think to look outside the ASA. I was too focused on the details of the conf.
/thomas
