URGENT-NAT PROBLEM
Antonio Simoes
I have a client with the diagram below, we beleave having a missconfiguration in NAT.
Because:
Inside computers 192.168.15.0/24,192.168.115.0/24  can´t access outside networks. But can acess webserver on DMZ.
Outside networks acess DMZ and inside computers beind static NAT rules.
Atention. The web server must access SQL server at inside network.
We have this configuration on ASA 5505 SEC plus license:
interface Ethernet0/0
switchport trunk allowed vlan 20
switchport mode trunk
interface Ethernet0/1
interface Ethernet0/2
shutdown
interface Ethernet0/3
switchport access vlan 3
interface Ethernet0/4
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
interface Vlan1
nameif inside
security-level 100
ip address 10.0.34.1 255.255.255.252
interface Vlan3
nameif dmz
security-level 70
ip address 192.168.70.254 255.255.255.0
interface Vlan20
nameif outside
security-level 0
ip address 72.72.72.66 255.255.255.252
ftp mode passive
dns server-group DefaultDNS
domain-name none.pt
object-group service DM_INLINE_SERVICE_1
service-object tcp eq 1433
service-object tcp eq domain
service-object udp eq 1434
service-object udp eq domain
access-list outside_access_in extended permit tcp any host 72.72.72.66 eq 100
access-list outside_access_in extended permit tcp any host 72.72.72.66 eq 20115
access-list outside_access_in extended permit tcp any host 72.72.72.66 eq 20119
access-list outside_access_in extended permit tcp any host 72.72.72.66 eq 90
access-list outside_access_in extended permit tcp any host 72.72.72.66 eq pptp
access-list outside_access_in extended permit tcp any host 72.72.72.66 eq www
access-list outside_access_in extended permit tcp any host 72.72.72.66 eq 9000
access-list outside_access_in extended permit tcp any host 72.72.72.66 eq ftp
access-list outside_access_in extended permit udp any host 72.72.72.66 eq 21
access-list outside_access_in extended permit udp any host 72.72.72.66 eq 100
access-list outside_access_in extended permit udp any host 72.72.72.66 eq 9000
access-list outside_access_in extended permit udp any host 72.72.72.66 eq 20119
access-list outside_access_in extended permit udp any host 72.72.72.66 eq 1723
access-list outside_access_in extended permit udp any host 72.72.72.66 eq www
access-list outside_access_in extended permit udp any host 72.72.72.66 eq 20115
access-list outside_access_in extended permit tcp any host 72.72.72.66 eq https
access-list outside_access_in extended permit udp any host 72.72.72.66 eq 443
access-list dmz_access_in extended permit object-group DM_INLINE_SERVICE_1 host 192.168.70.1 192.168.15.0 255.255.255.0
access-list outside_1_cryptomap extended permit ip 192.168.115.0 255.255.255.0 192.0.10.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.115.0 255.255.255.0 192.0.10.0 255.255.255.0
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 10.0.34.0 255.255.255.252
nat (dmz) 1 192.168.70.0 255.255.255.0
static (inside,outside) tcp interface telnet 192.168.15.1 telnet netmask 255.255.255.255
static (inside,outside) tcp interface 20115 192.168.15.1 3389 netmask 255.255.255.255
static (inside,outside) tcp interface pptp 192.168.15.1 pptp netmask 255.255.255.255
static (inside,outside) udp interface 1723 192.168.15.1 1723 netmask 255.255.255.255
static (inside,outside) udp interface 9000 192.168.15.1 8080 netmask 255.255.255.255
static (inside,outside) tcp interface 9000 192.168.15.1 8080 netmask 255.255.255.255
static (inside,outside) tcp interface ftp 192.168.15.1 ftp netmask 255.255.255.255
static (inside,outside) udp interface 21 192.168.15.1 21 netmask 255.255.255.255
static (dmz,outside) tcp interface 100 192.168.70.1 100 netmask 255.255.255.255
static (dmz,outside) udp interface 100 192.168.70.1 100 netmask 255.255.255.255
static (dmz,outside) udp interface 90 192.168.70.1 90 netmask 255.255.255.255
static (dmz,outside) tcp interface 90 192.168.70.1 90 netmask 255.255.255.255
static (dmz,outside) tcp interface 20119 192.168.70.1 3389 netmask 255.255.255.255
static (dmz,outside) udp interface 20119 192.168.70.1 3389 netmask 255.255.255.255
static (dmz,outside) udp interface www 192.168.70.1 www netmask 255.255.255.255
static (dmz,outside) tcp interface www 192.168.70.1 www netmask 255.255.255.255
static (dmz,outside) udp interface 443 192.168.70.1 443 netmask 255.255.255.255
static (dmz,outside) tcp interface https 192.168.70.1 https netmask 255.255.255.255
access-group dmz_access_in in interface dmz
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 72.72.72.651
route inside 192.168.1.0 255.255.255.0 10.0.34.2 1
route inside 192.168.15.0 255.255.255.0 10.0.34.2 1
route inside 192.168.30.0 255.255.255.0 10.0.34.2 1
route inside 192.168.115.0 255.255.255.0 10.0.34.2 1
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set connection-type originate-only
crypto map outside_map 1 set peer 81.81.81.81
crypto map outside_map 1 set transform-set ESP-3DES-MD5
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 1
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username admin password f3UhLvUj1QsXsuK7 encrypted
tunnel-group 81.81.81.81type ipsec-l2l
tunnel-group 81.81.81.81ipsec-attributes
pre-shared-key 20fhc2010
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
inspect http
inspect pptp
inspect snmp
inspect ipsec-pass-thru
inspect icmp
service-policy global_policy global
prompt hostname context
call-home reporting anonymous
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:6189b758b89e1dd1ed31ccfb731ad27c
: end
Some help plzzz......
Kind Regards
AS
You should add Static Identity NAT for the "inside" networks
static (inside,dmz) 192.168.15.0 192.168.15.0 netmask 255.255.255.0
static (inside,dmz) 192.168.115.0 192.168.115.0 netmask 255.255.255.0
- Jouni
5 Replies 5
Jouni Forss
You dont have the "nat" statements/configurations for the "inside" networks
Add
nat (inside) 1 192.168.15.0 255.255.255.0
nat (inside) 1 192.168.115.0 255.255.255.0
- Jouni
I´ll try it.
Thankx,
AS
Hi J,
When I put this command lines to nat the nat with the dmz crashes and the server in dmz dont comunicate with inside network as inside network don´t comunicate with DMZ.
5Sep 21 201309:12:22
192.168.15.11434
Asymmetric NAT rules matched for forward and reverse flows; Connection for udp src dmz:192.168.7
0.1/5292 dst inside:192.168.15.1/1434 denied due to NAT reverse path failure
3Sep 21 201309:18:57
192.168.70.1
portmap translation creation failed for icmp src inside:192.168.15.122 dst dmz:192.168.70.1 (type 8, code 0)
Remember I´m in a ASA 5505 Sec Plus and NAt control is activated. I know that influences the nat commands to be set. I tried a fiew but no success.
Any tip ???
AS
- Jouni
Hi J,
It worked. Thanks a lot.
[]´s
AS
