Using ASA for intervlan routing
net buzz
Level 3
Level 3
Hi!
Can the ASA firewall be used to perform intervlan routing in the same way that a router would be used. (Router-on-a-stick).
Alvin
3 Accepted Solutions
Yes you can
is your question clear?
Yes you can
