Very odd issue...need help
burleyman
Level 8
Level 8
I have an ASA that is running 9.1(1)
I have customers that use an application that goes to my outside IP address using TCP port 15678 and redirects it to a server in the DMZ with an IP address of 10.2.1.22.
Here is the configuration for that to happen.
interface GigabitEthernet0/1
 nameif outside
 security-level 0
 ip address 128.1.1.2 255.255.255.248
interface GigabitEthernet0/2
 description connection to DMZ interface
 nameif DMZ
 security-level 50
 ip address 10.2.1.254 255.255.255.0
object network OBJ-10.2.1.22_32
 host 10.2.1.22
object service OBJ-TCP-15678
 service tcp source eq 15678
access-list outside_access_in extended permit tcp any4 object OBJ-10.2.1.22_32 eq 15678
nat (DMZ,outside) source static OBJ-10.2.1.22_32 interface service OBJ-TCP-15678 OBJ-TCP-15678
route outside 0.0.0.0 0.0.0.0 128.1.1.1
Now the very odd issue.
all customers that have this setup are running with no issues except one.
They are coming from an IP address of 50.50.50.54 and they do not get connected to the server on the DMZ and here is what I see in the logs.
6|Oct 20 2015|10:21:32|106015|10.2.1.22|15678|50.50.50.54|61991|Deny TCP (no connection) from 10.2.1.22/15678 to 50.50.50.54/61991 flags SYN ACK  on interface inside
Why does it say "SYN ACK on interface inside"? and not DMZ? I think this is where the issue lies but I don't know what is causing it. What should I be looking at?
Mike
11 Replies 11
Jon Marshall
Mike
What does the routing table look like ?
What does a packet tracer show ie. -
"packet-tracer input outside tcp 50.50.50.54 12345 <public IP of server> 15678"
Jon
ASA# show route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is 128.1.1.1 to network 0.0.0.0
C    172.16.1.0 255.255.255.0 is directly connected, inside
C    60.60.60.0 255.255.255.252 is directly connected, backup
C    128.1.1.0 255.255.255.248 is directly connected, outside
C    10.2.1.0 255.255.255.0 is directly connected, DMZ
S    10.2.2.0 255.255.255.0 [1/0] via 128.1.1.1, outside
                            [1/0] via 60.60.60.1, outside
S    10.169.3.0 255.255.255.0 [1/0] via 128.1.1.1, outside
S    192.168.2.0 255.255.255.0 [1/0] via 128.1.1.1, outside
S*   0.0.0.0 0.0.0.0 [1/0] via 128.1.1.1, outside
ASA# packet-tracer input outside tcp 50.50.50.54 12345 10.2.1.22 15678
Phase: 1
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
Additional Information:
MAC Access list
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   10.2.1.0        255.255.255.0   DMZ
Phase: 4
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group outside_access_in in interface outside
Phase: 5
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 7
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
Phase: 8
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: DMZ
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Not sure why the drop.....
Mike
The drop is because you used the private IP of the server and not the public IP.
However I should have asked for it the other way round.
Can you run this -
"packet-tracer input DMZ tcp 10.1.2.22 15678 50.50.50.54 12345"
Jon
ASA# packet-tracer input DMZ tcp 10.1.2.22 15678 50.50.50.54 12345
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   0.0.0.0         0.0.0.0         outside
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group DMZ_access_in in interface DMZ
access-list DMZ_access_in extended permit ip any any
Phase: 3
Type: NAT
Result: ALLOW
Config:
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: NAT
Result: ALLOW
Config:
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 7
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 5144622, packet dispatched to next module
Result:
input-interface: DMZ
input-status: up
output-interface: outside
output-status: up
Action: allow
When I do the command show conn here is what I get for a site that works and one for the site that does not.
Works
TCP outside  75.75.75.225:1054 DMZ  10.2.1.22:15678, idle 0:00:00, bytes 766, flags UIOB
Does not work
TCP outside  50.50.50.54:61525 DMZ  10.2.1.22:15678, idle 0:00:01, bytes 0, flags SaAB
Mike
Mike
The packet tracer output looks okay.
The "sh conn" output ties up with your logs ie. the flags for the connection that doesn't work indicates a SYN packet has been received by the server but obviously if the SYN ACK is going to the inside interface then the remote device doesn't receive it and so never sends the ACK.
So something in your configuration must be sending that traffic to the inside but it isn't your route table as far as I can see.
Sorry to be a pain but can you run the original packet tracer again but this time use the public IP of the server.
Jon
No bother and thank you for your help. I went over the config again and nothing that should send the traffic to the inside interface. In fact this is pretty much the only rule in the ASA. It is only there to do pretty much this one thing.
ASA# packet-tracer input DMZ tcp 128.1.1.2 15678 50.50.50.54 12345
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 3
Type: NAT
Result: ALLOW
Config:
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: NAT
Result: ALLOW
Config:
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 7
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 5180851, packet dispatched to next module
Result:
input-status: up
output-status: up
Action: allow
Mike
To say it is odd is an understatement :-)
I can't see why it would send that traffic to the inside interface.
I am happy to provide a second pair of eyes on the configuration if you want to post it but you know what you are doing so I doubt I will spot anything.
Jon
I know.....These are fun and frustrating all at the same time.
I could post the config later but I don't think it would help very much because it is pretty much and default route and the config I posted, very basic. And it is working for everyone else but just this one customer and possibly a couple others but 50 to 100 others work just fine.
Mike
Hi Mike,
From the syslogs it looks like the SYN ACK is coming on the inside interface.
It is possible that you have some routing issue in your internal network due to which the reply traffic is coming to the inside interface.
Can you try to do traceroute from internal machine with IP 10.2.1.22 for any public IP and see how traffic flows.
Do share your findings.
R.Seth
A reboot of the server resolved the issue. I believe the DMZ server was for some reason send that traffic inside. I think it was the application and the transactions it does got messed up and routed the traffic for only a few transactions  to the inside.
Thank you everyone for your help.
Mike
Glad that the issue is resolved. :)
R.Seth
