11-12-2004 08:01 AM - edited 02-20-2020 11:44 PM
With the following configuration:
PIX Version 6.3(3)
interface ethernet0 100full
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxx
passwd xxxx
hostname Pix-Sacyr
domain-name sacyr.cl
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list 100 permit ip 192.168.206.0 255.255.255.0 10.10.10.0 255.255.255.0
access-list split-tunel permit ip 192.168.206.0 255.255.255.0 10.10.10.0 255.255
.255.0
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 200.x.x.x.x.255.248
ip address inside 192.168.206.2 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool soporte 10.10.10.1-10.10.10.20
pdm location 10.10.10.2 255.255.255.255 inside
pdm location 192.168.206.1 255.255.255.255 inside
pdm location 10.10.10.2 255.255.255.255 outside
pdm location 10.10.10.0 255.255.255.0 outside
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list 100
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) 200.x.x.x.168.206.1
netmask 255.255.255.255 0 0
conduit permit icmp any any
conduit permit tcp host 200.68.22.108 eq smtp any
conduit permit tcp host 200.68.22.108 eq pop3 any
conduit permit tcp host 200.68.22.108 eq www any
route outside 0.0.0.0 0.0.0.0 200.68.22.105 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 10.10.x.x.x.255.255 outside
http 10.10.10.2 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap client configuration address initiate
crypto map mymap client configuration address respond
crypto map mymap interface outside
isakmp enable outside
isakmp identity address
isakmp nat-traversal 20
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup soporte address-pool soporte
vpngroup soporte split-tunnel split-tunel
vpngroup soporte idle-time 1800
vpngroup soporte password ********
telnet 10.10.x.x.x.255.0 outside
telnet 192.168.206.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
I can telnet into the pix with vpn client 3.6x, but with the vpn client version 4.x just the ping is working, and I can not telnet to the PIX.
Both client are intalled in windows 2k, the differences that I can see is with version 4.x in the windows 2k assign
Ethernet adaptador Conexión de área local:
Sufijo DNS específico de la conexión. :
Dirección IP. . . . . . . . . . . . . : 10.10.10.3
Máscara de subred . . . . . . . . . . : 255.0.0.0
Puerta de enlace predeterminada . . . :
With version 3.6 didn´t appear ip assigned with the ipconfig command.
Does anyone have the same problem?
11-12-2004 09:37 AM
The 4.0 creates a SA differnt then the 3.x clients. Use the management command and set it up for the inside interface and you will be able to telnet to the inside ip address ofthe pix.
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/cmdref/mr.htm#wp1137951
11-15-2004 05:21 AM
Two question, it regarding the PIX should be management remotely.
1) Can be management by outside interface, with "management-access command", I did a test and it didn´t work
2) Can be management using the two client version
11-15-2004 07:42 AM
again, you need to set it up to the inside interface. and, from your client you need to telnet to the inside interface.
Yes you can manage the pix using both clients. Once you do the "management-access inside". You will be able to telnet into the inside interface with both clients. Or, you can telnet to the ouside interface with the 3.x client and telnet to the inside interface with the 4.x client.
12-06-2004 09:51 PM
Also.... you can add the external interface to the access list allowing traffic from the VPN client network into the protected LAN and you will be able to access the external interface...
