VPN connection
m.metwally
Dear All,
I have configured my ASA 5510 with remote VPN, I can connect from my PC to my Network through this VPN and I can ping any PC in the network BUT, I cannot telnet or open any PC in the network using Remote Desktop Connection. is these needs more configuration?
please help with details, Appreciated
Check for the proper routes...
- other PC's going to the vpn ip pool and - from the firewall to the PC's.
Also if you have used any ACL for split tunelling you might have to permit the connection to the other PC's.
