VPN -- Point to Point Connection Routing.
The VPN is up and running between Site C and Site A. No problem there.
I can ping 10.2.24.1 from Site A P2P Router.
But I cannot ping from Site B P2P Router. The ping times out.
I have the following routes on 3 routers,
Site A P2P Router: ip route 10.2.24.0 255.255.255.0 172.16.5.3
Site B P2P Router:  ip route 10.2.24.0 255.255.255.0 172.16.5.3
Site B Router Gateway:  ip route 10.2.24.0 255.255.255.0 172.16.5.3
When i start a ping from 172.20.3.0/24 network, Site C see the ping coming from 172.20.3.0 network and sends out a reply. But I never get a reply and i get a request timed out.
My task is that i should be able to ping Site C from any machine at Site B
9 Replies 9
andrew.prince
Level 10
Level 10
Your next hops should be 1 away unless you are running a dynamic routing protocol.
Change:-
Site B P2P Router:  ip route 10.2.24.0 255.255.255.0 172.16.5.3 change to
ip route 10.2.24.0 255.255.255.0 172.16.1.5
Site B Router Gateway:  ip route 10.2.24.0 255.255.255.0 172.16.5.3 change to
ip route 10.2.24.0 255.255.255.0 172.20.3.2
And ensure the correct IP subnets are part of the interesting traffic acl and the no-nat acl.
HTH>
I changed the routes to what you suggested. but still its the same. The ping to Site C network times out if i do from a Site B machine.
Any other suggestion?
Post the output from a traceroute from the Site B Machine.  And check to make sure the site B IP subnet is on the list of interesting traffic for the VPN, and it is not be double natted.
I cannot do a traceroute becuase the guy who manages Site C has disabled tracerouting. When I ping Site C from Site B, Site C does see that the packet is coming from Site B and sends out a reply. But I receive a 'request timed out' on Site B. So it seems like the packet gets dropped between Site A P2P router and Site B P2P router.
How is that possible - if someone else manages site C, how can you see site C respond?  What firewalls terminate the VPN?
He said to me that he can see traffic coming from Site B. Both firewalls at Site A and Site C are Cisco ASAs
Something does not sounds right.
Post the output from the command "show crypto ipsec sa" from both devices, and "show access-list" from both devcies
Andrew,
Found the issue. I was missing a route on Firewall Site A to send Site B traffic via the Core Switch at Site A. Core Switch does the routing. Adding that everything started working.
Thanks for your help!!!
Pratik
good news
