webserver not accessible locally from inside to outside
casper1
Hi everyone,
      i am having a problem accessing my web server from local network while the same website is accessible from any other external network .
in my topology web server is on DMZ mapped to external public IP address via static NAT while i am connected to inside network i am unable to access the website URL while server itself is accessible for management. the same issue is with my Vpn. i am using CISCO ASA 5550 . anybody ever encountered such situation ?? Please guide if someone has solution to it
Abheesh Kumar
Please do a packet trace and share the output.
packet-tracer input inside tcp (insideIP) 44444 (DMZServerIP) http
Hope This Helps
Abheesh
Sheraz.Salim
it could be you have some access-list blocking the packet. please share the config. and as @Abheesh Kumar said give us a packet tracer output in order to help you on this.
please do not forget to rate.
