weird nat problem ???!!!!
baraa272
Community Member
hi everyone of the community
today i stumbled upon such a weird and annoying nat problem
simply i have two networks and theres eigrp applied
and i can ping any computer within the 2 networks
the problem appeared when i started applying NAT
first when i applied the PAT on "ppp" the nat works and i still can ping
then when i applied PAT on "mikrotik"
then i lost the ability to ping any computer within the 2 networks
heres config 'MIKROTIK"
Building configuration...
Current configuration : 1401 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname mikrotik
ip dhcp excluded-address 192.168.88.1 192.168.88.10
ip dhcp pool pp.ps
 network 192.168.88.0 255.255.255.0
 default-router 192.168.88.1
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX15241P58
spanning-tree mode pvst
interface GigabitEthernet0/0
 ip address 192.168.88.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
 shutdown
interface GigabitEthernet0/2
 no ip address
 duplex auto
 speed auto
 shutdown
interface Serial0/0/0
 ip address 85.64.25.11 255.255.0.0
 ip nat outside
interface Serial0/0/1
 no ip address
 clock rate 2000000
interface Serial0/1/0
 no ip address
 clock rate 2000000
interface Serial0/1/1
 no ip address
 clock rate 2000000
interface Serial0/2/0
 no ip address
 clock rate 2000000
interface Serial0/2/1
 no ip address
 clock rate 2000000
interface Vlan1
 no ip address
 shutdown
router eigrp 1
 network 85.64.0.0 0.0.255.255
ip nat inside source list 1 interface Serial0/0/0 overload
ip classless
ip flow-export version 9
access-list 1 permit 192.168.88.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
 login
end
config "ppp"
Current configuration : 1218 bytes
version 15.1
hostname ppp
no ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX152468BI
 ip nat inside
 duplex auto
 speed auto
 no ip address
 duplex auto
 speed auto
 shutdown
 no ip address
 duplex auto
 speed auto
 shutdown
 ip address 85.64.25.15 255.255.0.0
 ip nat outside
 clock rate 64000
 no ip address
 clock rate 2000000
 shutdown
 no ip address
 clock rate 2000000
 shutdown
 no ip address
 clock rate 2000000
 shutdown
interface Vlan1
 no ip address
 shutdown
router eigrp 1
 network 192.168.1.0
ip classless
access-list 1 permit 192.168.1.0 0.0.0.255
ip access-list standard nat
line con 0
line aux 0
line vty 0 4
 login
end
PS.ROUTERS can ping any client but clients cant ping
7 Replies 7
Pawan Raut
Level 10
Level 10
This is beacuse of asymetric NAT issue.
Kindly note that PAT is use to NAT the source for outbound connection.
Here in this case you are intiating connection from mikrotik loaction to ppplocation for ppp its inbound connection and that PAT on ppp router create asyemtric nat issue.
Lets consider PC1 behind mikrotik has IP address 192.168.88.10 and PC4 behind PPP has IP 192.168.1.10
So PC1 ping to PC2 that is Source: 192.168.88.10 destination: 192.168.1.10
on router mikrotik beacuse of PAT rule source getting NAT for outbound connection so now Source: 85.64.25.11 destination: 192.168.1.10
But on router PPP the connection is inbound so it will ignore the PAT and Source: 85.64.25.11 destination: 192.168.1.10.
So packet reaches to PC4 and it send ICMP reply back to PC1 now here source is Source: 192.168.1.10 destination: 85.64.25.11.
on router PPP baecause of PAT rule source getting NAT for outbound connection so now Source:85.64.25.15 destination: 85.64.25.11.
But the router mikrotik expecting icmp reply from source IP 192.168.1.10 and not from 85.64.25.15
192.168.88.x -->85.64.25.11
ppp
192.168.1.y -->85.64.25.15
Pawan (CCIE#52104)
Kindly Rate for helpful post
what can i do to fix this problem?????
Also I noticed you used same subnet 85.64.0.0/16 on outside interface on both router you can split the subnet into two and use 85.64.0.0/17 on mikrotik router outside interface and 85.64.128.0/17 on ppp router outside interface.
For NAT you can use static host to host nat instead on PAT.
on router  mikrotik
ip nat inside source static <PC1 IP address> 85.64.0.10
on router  PPP
ip nat inside source static <PC4 IP address> 85.64.128.10
Hope this will help you
using static not a solution!
i want the 2 networks to be behind NAT with 1 address
192.168.1.0 >>>> ppp router ip address
192.168.88.0 >>>> mikrotik ip address
and i want a real solution for this problem!
does cisco routers cant do that????? like cheap home/office routers!!!???
What you really want to achive.Cisco router can do that and home router dont allow any inbound connections.
if you own tp link router with RIP you can easily apply nat
so can you tell me how i can fix this problem in packet tracer or at least how i can do that ????!!!
You can do the PAT as you alreday did but you will not able to ping the end to end IP address.
