cherifi.m85
As you may have noticed from my previous blogs, I have contributed to Cisco Devnet Automation Exchange with 04 Projects.
Here is a review as a reminder:
Genie_Webex Project
Validate/Maintain Network Devices Configuration
This project combines two Cisco solution : Webex Teams and Genie/pyATS. The goal is to check the state of the routers if there is any change in the desired configuration. Cisco Webex Teams is used to receive alerts for the result: Configuration change or not. Genie/pyATS is used to test and compare the configuration with its functions and APIs.
Here the link: https://developer.cisco.com/codeexchange/github/repo/cherifimehdi/Genie_Webex
Check_Access Project
This project leverages Genie/pyATS  framework, WebEx Messenger  and python logging module  to check access into network devices by displaying, sending the result to WebEx Messenger Space and triggering logs to Syslog server for information and maintenance purposes.
Here the link: https://developer.cisco.com/codeexchange/github/repo/cherifimehdi/Check_Access
Efficient Network Devices Data Retrieving - Application case of Validate/Monitor access to network devices with the integration of Genie/pyATS, WebEx Messenger and Syslog server use case
This project shows an efficent and optimized way to retrieve data from network devices with checking access process by leveraging the Validate/Monitor access to network devices with the integration of Genie/pyATS, WebEx Messenger and Syslog server  use case relating with the project Check_Access .
Suppose we have 100 network devices and we have access only to 50 of them, the retriving data process is applied only to these 50 devices witch conduct to save the time with generating logs to Syslog server for maintenance purposes besides the report sent to WebEx Messenger Space.
Here the link: https://developer.cisco.com/codeexchange/github/repo/cherifimehdi/Retrieve_Data_Application_Case
Auto web-based graphical check access to network devices
This project aims to generates automatically the topology of the entreprise showing if there is an access to the network devices.
Here the link: https://developer.cisco.com/codeexchange/github/repo/cherifimehdi/Graphical_Check_Access
Here my Github in case you find something interesting!: My GitHub
Don't forget, I need your encouragement and comment with feedback! If you like my contribution RATE it!
Thank you and see you soon!
4 Comments
