karthikragugb
I have a cisco L3 3850 catalyst switch connected to 5 stacks of L2 cisco 2960 switches. Suddenly amber light comes in stack 3 and stack 4 switches that too from port 25 to 46 alone in both stacks. That time network disconnects for few seconds and comes back to green.The same configuration has been running for around 4 years but suddenly issue araises now. Kindly help
1 Comment
Leo Laohoo
Post the complete output to the following commands:
  1. sh version
  2. sh post
  3. sh interface status err
pri_core#sh version
Cisco IOS Software [Denali], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 16.3.6, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Wed 28-Feb-18 15:23 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2018 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 3.58, RELEASE SOFTWARE (P)
pri_core uptime is 4 years, 28 weeks, 17 hours, 27 minutes
Uptime for this control processor is 4 years, 28 weeks, 17 hours, 30 minutes
System returned to ROM by SSO Switchover
System image file is "flash:packages.conf"
Last reload reason: Power Failure
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
ipbasek9 Permanent ipbasek9
cisco WS-C3850-24T (MIPS) processor (revision AC0) with 864936K/6147K bytes of memory.
Processor board ID FOC2212L0YB
12 Virtual Ethernet interfaces
56 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
252000K bytes of Crash Files at crashinfo:.
1611414K bytes of Flash at flash:.
0K bytes of at webui:.
252000K bytes of Crash Files at crashinfo-1:.
1611414K bytes of Flash at flash-1:.
Base Ethernet MAC Address : 70:01:b5:99:18:00
Motherboard Assembly Number : 73-16297-05
Motherboard Serial Number : FOC2210744N
Model Revision Number : AC0
Motherboard Revision Number : B0
Model Number : WS-C3850-24T
System Serial Number : FOC2212L0YB
Switch Ports Model SW Version SW Image Mode
1 32 WS-C3850-24T 16.3.6 CAT3K_CAA-UNIVERSALK9 INSTALL
* 2 32 WS-C3850-24T 16.3.6 CAT3K_CAA-UNIVERSALK9 INSTALL
Switch 01
Switch uptime : 5 hours, 36 minutes
Base Ethernet MAC Address : 70:01:b5:99:10:00
Motherboard Serial Number : FOC221074KH
System Serial Number : FOC2212L0YA
Configuration register is 0x102
pri_core#sh post
Stored system POST messages:
Switch 1
POST: MBIST Tests : Begin
POST: MBIST Tests : End, Status Passed
POST: CRYPTO Tests : Begin
POST: CRYPTO Tests : End, Status Passed
POST: PHY Loopback: loopback Test : Begin
POST: PHY Loopback: loopback Test : End, Status Passed
POST: Thermal, Temperature Tests : Begin
POST: Thermal, Temperature Tests : End, Status Passed
POST: Thermal, Fan Tests : Begin
POST: Thermal, Fan Tests : End, Status Passed
POST: SIF Tests : Begin
POST: SIF Tests : End, Status Passed
Switch 2
