Hi Everybody!
I am trying to get the configuration from a nexus 9000v virtualized in my home lab, I am always getting this error.
Exception has occurred: RPCError
Namespace="http://openconfig.net/yang/interfaces"
  File "C:\4_4 Modernizing_Network_infra_NETCONF\get_config.py", line 58, in main
    resp = conn.get_config(source="running", filter=("subtree", nc_filter))
  File "C:\4_4 Modernizing_Network_infra_NETCONF\get_config.py", line 92, in <module>
    main()
This is the complete code, it is one of the lab exercises in Pluralsight site and it is public.
#!/usr/bin/env python
Author: Nick Russo
Purpose: Using NETCONF with Openconfig YANG models to collect switchport
configs on a Cisco NX-OS switch via the always-on Cisco DevNet sandbox.
import xmltodict
from ncclient import manager
def main():
    Execution begins here.
    # Dictionary containing keyword arguments (kwargs) for connecting
    # via NETCONF. Because SSH is the underlying transport, there are
    # several minor options to set up.
    connect_params = {
        "host": "192.168.50.253",
        "port": 830,
        "username": "admin",
        "password": "*",
        "hostkey_verify": False,
        "allow_agent": False,
        "look_for_keys": False,
        "device_params": {"name": "nexus"},
    # Unpack the connect_params dict and use them to connect inside
    # of a "with" context manager. The variable "conn" represents the
    # NETCONF connection to the device.
    with manager.connect(**connect_params) as conn:
        print("NETCONF session connected")
        # To save time, only capture 3 switchports. Less specific filters
        # will return more information, but take longer to process/transport.
        # Note: In this sandbox, it can take ~30 seconds to get all interfaces
        # and several minutes to get the whole config, so be aware!
        nc_filter = """
            <interfaces xmlns="http://openconfig.net/yang/interfaces">
                <interface>
                    <name>eth1/2</name>
                </interface>
                <interface>
                    <name>eth1/3</name>
                </interface>
                <interface>
                    <name>eth1/4</name>
                </interface>
            </interfaces>
        # Execute a "get-config" RPC using the filter defined above
        # Uncomment line below to see raw RPC XML reply; great for learning
        # print(resp.xml)
        # Parse the XML text into a Python dictionary
        jresp = xmltodict.parse(resp.xml)
        # Uncomment line below to see parsed JSON RPC; great for learning
        # import json; print(json.dumps(jresp, indent=2))
        # Iterate over all the interfaces returned by helper function
        for intf in jresp["rpc-reply"]["data"]["interfaces"]["interface"]:
            # Declare a few local variables to make accessing data deep
            # within the JSON structure a little easier
            config = intf["ethernet"]["switched-vlan"]["config"]
            mode = config["interface-mode"].lower()
            # Print common switchport data
            print(f"Name: {intf['name']:<7}  Type: {mode:<6}", end="  ")
            # Print additional data depending on access vs trunk ports
            if mode == "access":
                print(f"Access VLAN: {config['access-vlan']}")
            elif mode == "trunk":
                print(f"Native VLAN: {config['native-vlan']}")
            else:
                print("(no additional data)")
    print("NETCONF session disconnected")
if __name__ == "__main__":
    main()
The issue is that, it works perfectly in the DevNet Sandbox. Of course, the connection parameters are different of course.
    connect_params = {
        "host": "sbx-nxos-mgmt.cisco.com",
        "port": 10000,
        "password": "*",
This is the image I am testing with Nexus in my home lab.
Nexus 9000v is a demo version of the Nexus Operating System
Software
  BIOS: version
  NXOS: version 7.0(3)I7(3)
  BIOS compile time:
  NXOS image file is: bootflash:///nxos.7.0.3.I7.3.bin
  NXOS compile time:  2/12/2018 13:00:00 [02/12/2018 19:13:48]
Hardware
  cisco Nexus9000 9000v Chassis
This is the Nexus image that Cisco has public access in DevNet sandbox.
Software
  BIOS: version
 NXOS: version 9.3(3)
  BIOS compile time:
  NXOS image file is: bootflash:///nxos.9.3.3.bin
  NXOS compile time:  12/22/2019 2:00:00 [12/22/2019 14:00:37]
Hardware
  cisco Nexus9000 C9300v Chassis
I have enabled netconf already
NX1# show run | sec netconf|username
feature netconf
username admin password 5 $5$BOPMCF$
 role network-admin
Could you please help me what is going on?
4 Comments
