Hi Everybody!
I am trying to get the configuration from a nexus 9000v virtualized in my home lab, I am always getting this error.
Exception has occurred: RPCError
Namespace="http://openconfig.net/yang/interfaces"
  File "C:\4_4 Modernizing_Network_infra_NETCONF\get_config.py", line 58, in main
    resp = conn.get_config(source="running", filter=("subtree", nc_filter))
  File "C:\4_4 Modernizing_Network_infra_NETCONF\get_config.py", line 92, in <module>
    main()
This is the complete code, it is one of the lab exercises in Pluralsight site and it is public.
#!/usr/bin/env python
Author: Nick Russo
Purpose: Using NETCONF with Openconfig YANG models to collect switchport
configs on a Cisco NX-OS switch via the always-on Cisco DevNet sandbox.
import xmltodict
from ncclient import manager
def main():
    Execution begins here.
    # Dictionary containing keyword arguments (kwargs) for connecting
    # via NETCONF. Because SSH is the underlying transport, there are
    # several minor options to set up.
    connect_params = {
        "host": "192.168.50.253",
        "port": 830,
        "username": "admin",
        "password": "*",
        "hostkey_verify": False,
        "allow_agent": False,
        "look_for_keys": False,
        "device_params": {"name": "nexus"},
    # Unpack the connect_params dict and use them to connect inside
    # of a "with" context manager. The variable "conn" represents the
    # NETCONF connection to the device.
    with manager.connect(**connect_params) as conn:
        print("NETCONF session connected")
        # To save time, only capture 3 switchports. Less specific filters
        # will return more information, but take longer to process/transport.
        # Note: In this sandbox, it can take ~30 seconds to get all interfaces
        # and several minutes to get the whole config, so be aware!
        nc_filter = """
            <interfaces xmlns="http://openconfig.net/yang/interfaces">
                <interface>
                    <name>eth1/2</name>
                </interface>
                <interface>
                    <name>eth1/3</name>
                </interface>
                <interface>
                    <name>eth1/4</name>
                </interface>
            </interfaces>
        # Execute a "get-config" RPC using the filter defined above
        # Uncomment line below to see raw RPC XML reply; great for learning
        # print(resp.xml)
        # Parse the XML text into a Python dictionary
        jresp = xmltodict.parse(resp.xml)
        # Uncomment line below to see parsed JSON RPC; great for learning
        # import json; print(json.dumps(jresp, indent=2))
        # Iterate over all the interfaces returned by helper function
        for intf in jresp["rpc-reply"]["data"]["interfaces"]["interface"]:
            # Declare a few local variables to make accessing data deep
            # within the JSON structure a little easier
            config = intf["ethernet"]["switched-vlan"]["config"]
            mode = config["interface-mode"].lower()
            # Print common switchport data
            print(f"Name: {intf['name']:<7}  Type: {mode:<6}", end="  ")
            # Print additional data depending on access vs trunk ports
            if mode == "access":
                print(f"Access VLAN: {config['access-vlan']}")
            elif mode == "trunk":
                print(f"Native VLAN: {config['native-vlan']}")
            else:
                print("(no additional data)")
    print("NETCONF session disconnected")
if __name__ == "__main__":
    main()
The issue is that, it works perfectly in the DevNet Sandbox. Of course, the connection parameters are different of course.
    connect_params = {
        "host": "sbx-nxos-mgmt.cisco.com",
        "port": 10000,
        "password": "*",
This is the image I am testing with Nexus in my home lab.
Nexus 9000v is a demo version of the Nexus Operating System
Software
  BIOS: version
  NXOS: version 7.0(3)I7(3)
  BIOS compile time:
  NXOS image file is: bootflash:///nxos.7.0.3.I7.3.bin
  NXOS compile time:  2/12/2018 13:00:00 [02/12/2018 19:13:48]
Hardware
  cisco Nexus9000 9000v Chassis
This is the Nexus image that Cisco has public access in DevNet sandbox.
Software
  BIOS: version
 NXOS: version 9.3(3)
  BIOS compile time:
  NXOS image file is: bootflash:///nxos.9.3.3.bin
  NXOS compile time:  12/22/2019 2:00:00 [12/22/2019 14:00:37]
Hardware
  cisco Nexus9000 C9300v Chassis
I have enabled netconf already
NX1# show run | sec netconf|username
feature netconf
username admin password 5 $5$BOPMCF$
 role network-admin
Could you please help me what is going on?
4 Comments
omz
is not installed by default.
Follow this whitepaper to load the openconfig YANG model -
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-9000-series-switches/white-paper-c11-741518.html#_Toc528621687
and then give it a go again ..
Thank you very much, it worked perfectly.
<?xml version="1.0" encoding="UTF-8"?>
<rpc-reply message-id="urn:uuid:5c7a48e3-53a4-4d42-b691" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
    <data>
            <interface>
                <name>eth1/2</name>
                <config>
                    <enabled>true</enabled>
                    <mtu>1500</mtu>
                    <name>eth1/2</name>
                    <type xmlns:ianaift="urn:ietf:params:xml:ns:yang:iana-if-type">ianaift:ethernetCsmacd</type>
                </config>
                <hold-time>
                    <config>
                        <down>100</down>
                    </config>
                </hold-time>
                <subinterfaces>
                    <subinterface>
                        <config>
                            <index>0</index>
                        </config>
                        <index>0</index>
                    </subinterface>
                </subinterfaces>
                <ethernet xmlns="http://openconfig.net/yang/interfaces/ethernet">
                    <config>
                        <auto-negotiate>true</auto-negotiate>
                    </config>
                    <switched-vlan xmlns="http://openconfig.net/yang/vlan">
                        <config>
                            <access-vlan>1</access-vlan>
                            <interface-mode>ACCESS</interface-mode>
                            <native-vlan>1</native-vlan>
                        </config>
                    </switched-vlan>
                </ethernet>
            </interface>
            <interface>
                <name>eth1/3</name>
                <config>
                    <mtu>1500</mtu>
                    <name>eth1/3</name>
                </config>
                <hold-time>
                    <config>
                        <down>100</down>
                    </config>
                </hold-time>
                <subinterfaces>
                    <subinterface>
                        <config>
                            <index>0</index>
                        </config>
                        <index>0</index>
                    </subinterface>
                </subinterfaces>
                    <config>
                    </config>
                        <config>
                        </config>
                    </switched-vlan>
                </ethernet>
            </interface>
            <interface>
                <name>eth1/4</name>
                <config>
                    <mtu>1500</mtu>
                    <name>eth1/4</name>
                </config>
                <hold-time>
                    <config>
                        <down>100</down>
                    </config>
                </hold-time>
                <subinterfaces>
                    <subinterface>
                        <config>
                            <index>0</index>
                        </config>
                        <index>0</index>
                    </subinterface>
                </subinterfaces>
                    <config>
                    </config>
                        <config>
                        </config>
                    </switched-vlan>
                </ethernet>
            </interface>
        </interfaces>
    </data>
</rpc-reply>
Name: eth1/2   Type: access  Access VLAN: 1
Name: eth1/3   Type: access  Access VLAN: 1
Name: eth1/4   Type: access  Access VLAN: 1
At the begging I was having issues installing it like it worked with the command "install add bootflash:file.rpm activate.
I also had to update the OS from version 7 to version "NXOS: version 9.2(2)"
switch# run bash sudo su --- This worked at the beggining, but later the swtich did not accept the same command.
% Invalid command at '^' marker.
switch# run guestshell sudo su
Error: Guest shell is currently being enabled.
[root@guestshell admin]#
[root@guestshell bootflash]# ls -lsa
25868 -rw-r--r--  1 root  root            26455883 May 30 20:19 mtx-openconfig-all-1.0.0.0-9.2.1.lib32_n9000.rpm
n9000.rpmstshell bootflash]# yum install mtx-openconfig-all-1.0.0.0-9.2.1.lib32_n
Loaded plugins: fastestmirror
Examining mtx-openconfig-all-1.0.0.0-9.2.1.lib32_n9000.rpm: mtx-openconfig-all-1.0.0.0-9.2.1.lib32_n9000
Cannot add package mtx-openconfig-all-1.0.0.0-9.2.1.lib32_n9000.rpm to transaction. Not a compatible architecture: lib32_n9000
Error: Nothing to do
[root@guestshell bootflash]# exit
NX2# install add bootflash:mtx-openconfig-all-1.0.0.0-9.2.1.lib32_n9000.rpm activate
Adding the patch (/mtx-openconfig-all-1.0.0.0-9.2.1.lib32_n9000.rpm)
[####################] 100%
Install operation 1 completed successfully at Sat May 30 20:55:45 2020
Activating the patch (/mtx-openconfig-all-1.0.0.0-9.2.1.lib32_n9000.rpm)
Install operation 2 failed because package not compatible with running image at Sat May 30 20:55:50 2020
NX2# install add bootflash:mtx-openconfig-all-1.0.0.0-9.2.2.lib32_n9000.rpm activate
Adding the patch (/mtx-openconfig-all-1.0.0.0-9.2.2.lib32_n9000.rpm)
Install operation 3 completed successfully at Sat May 30 21:12:14 2020
omz
The install for 9.2.1 failed and you had you update the version because you downloaded 9.2.1 package.
You can remove the last part in the URL or up a directory level by click ../ and browse to all the packages you can download for previous versions as well.
https://devhub.cisco.com/artifactory/open-nxos-agents/
fracjackmac
Level 5
Level 5
Juan,
Thanks for all the great information in your post!  The link to the github page for the information that Nick Russo provided for his Pluralsight class was a bonus.
Vince S
@ittybittypacket
