kuliu2
As we discussing at meeting ,this is my plan for EEM .
purpose:
Between  BFD flap (Will end in about 3 seconds), get following log 5times.
show interface <IF>
show controllers npu diag counters graphical instance all location all
show captured packets ingress location <LC>
show captured packets egress location <LC>
show controllers npu stats traps-all instance all location all
show spp node-counters location all
Config :
aaa authorization commands eem-method none
aaa authorization eventmanager default local
line template eem-template
event manager directory user policy disk0:
event manager policy <script name> username cisco persist-time 3600
script:
::cisco::eem::event_register_syslog occurs 1 pattern ".*bfd_agent.*BFD session to neighbor.*has gone down" maxrun_sec 30
# EEM policy to monitor BFD
# Cisco Systems
# Copyright (c) 2010 by cisco Systems, Inc.
# All rights reserved.
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
# 1. query the information of latest triggered eem event
array set arr_einfo [event_reqinfo]
if {$_cerrno != 0} {
set result [format "component=%s; subsys err=%s; posix err=%s\ns" \
$_cerr_sub_num $_cerr_sub_err $_cerr_posix_err $_cerr_str]
error $result
set msg $arr_einfo(msg)
# 2. Execute the debug
if [catch {cli_open} result] {
error $result $errorInfo
} else {
array set cli1 $result
# 2. <IF> need to be specified
if [catch {cli_exec $cli1(fd) "show interface <IF> | file harddisk:show interface <IF>"} result] {
# Execute the CMD
if [catch {cli_exec $cli1(fd) "show controllers npu diag counters graphical instance all location all | file harddisk:show controllers npu"} result] {
# <LC> need to be specified
if [catch {cli_exec $cli1(fd) "show captured packets ingress location <LC> | file harddisk:show captured packets ingress"} result] {
if [catch {cli_exec $cli1(fd) "show captured packets egress location <LC> | file harddisk:show captured packets egress"} result] {
# Execute the CMD
if [catch {cli_exec $cli1(fd) "show controllers npu stats traps-all instance all location all | file harddisk:show controllers npu"} result] {
# Execute the CMD
if [catch {cli_exec $cli1(fd) "show spp node-counters location all | file harddisk:show spp"} result] {
# Execute the CMD
if [catch {cli_exec $cli1(fd) "show bfd session detail | file harddisk:show-bfd"} result] {
#Notify via a syslog message that we had this event.
action_syslog priority info msg "capture BFD info via EEM TCL!"
could you confirm.
Kun Liu
