SunilKhanna
    Introduction
    BGP Neighbors associated in a Peer-Group share similar routing policies. Update policies are usually set by route maps, distribute-lists and filter-lists, etc. Instead of defining the same policies for each separate neighbor, we define a peer group name and assign these policies to the peer group.
    Members of the peer group inherit all of the configuration options of the peer group. Members can also be configured to override these options if these options do not affect outbound updates; you can only override options set on the inbound.
    The command to configure peer group is neighbor peer-group-name peer-group and to associate a member to a group is neighbor {ipv4/ipv6 address} peer-group peer-group-name .
    NOTE: The members of a peer group may not necessarily be in a same autonomous system.
    Background
    In this documentation, we are configuring IPv6 EBGP relationship by creating two peer groups on Router R1, named BOISE and MONTANA. Neighbors associated in group BOISE are R2 & R3 whereas R4 & R5 are associated with group MONTANA. For demonstration, we have configured two route-maps for each peer-group.
    The command to attache peer-group with the route-map is neighbor peer-group-name route-map route-map-name out/in, the command is configured under the address-family mode.
    All configurations are carried in Lab environment on Cisco 3745 Router operating on Cisco IOS 12.4 version.
    Topology Summarization
    Topology Diagram
    Configuration
    Summary Steps
    1. enable
    2. configure terminal
    3. router bgp as-number
    4. neighbor peer-group-name peer-group
    5. neighbor {ip-address | ipv6-address[%] | peer-group-name} remote-as autonomous-system-number [alternate-as autonomous-system-number ...]
    6. address-family ipv6 [vrf vrf-name] [unicast | multicast | vpnv6
    7. neighbor {ip-address | peer-group-name | ipv6-address %} activate
    8. neighbor ip-address | ipv6-address} send-label
    9. neighbor {ip-address | ipv6-address} peer-group peer-group-name
    10. exit
    Router R1
    R1
    hostname R1
    ip cef
    no ip domain lookup
    ipv6 unicast-routing
    interface Serial0/2
    no ip address
    ipv6 address 2012:1:CA1:12::1/64
    ipv6 enable
    clock rate 72000
    interface Serial0/3
    no ip address
    ipv6 address 2012:1:CA1:13::1/64
    ipv6 enable
    clock rate 72000
    interface Serial0/4
    no ip address
    ipv6 address 2012:1:CA1:14::1/64
    ipv6 enable
    clock rate 72000
    interface Serial0/5
    no ip address
    ipv6 address 2012:1:CA1:15::1/64
    ipv6 enable
    clock rate 72000
    router bgp 100
    bgp router-id 1.1.1.1
    no bgp default ipv4-unicast
    bgp log-neighbor-changes
    neighbor BOISE peer-group
    neighbor MONTANA peer-group
    neighbor 2012:1:CA1:12::2 remote-as 22
    neighbor 2012:1:CA1:12::2 peer-group BOISE
    neighbor 2012:1:CA1:13::3 remote-as 33
    neighbor 2012:1:CA1:13::3 peer-group BOISE
    neighbor 2012:1:CA1:14::4 remote-as 44
    neighbor 2012:1:CA1:14::4 peer-group MONTANA
    neighbor 2012:1:CA1:15::5 remote-as 55
    neighbor 2012:1:CA1:15::5 peer-group MONTANA
    address-family ipv6
      neighbor BOISE route-map LIST1 out
      neighbor MONTANA route-map LIST2 out
      neighbor 2012:1:CA1:12::2 activate
      neighbor 2012:1:CA1:13::3 activate
      neighbor 2012:1:CA1:14::4 activate
      neighbor 2012:1:CA1:15::5 activate
      network 2012:1:CA1:11::1/64
      network 2012:1:CA1:22::2/64
    exit-address-family
    route-map LIST2 permit 10
    match ipv6 address LIST_2
    route-map LIST1 permit 10
    match ipv6 address LIST_1
    ipv6 access-list LIST_1
    permit ipv6 host 2012:1:CA1:11::1 any
    ipv6 access-list LIST_2
    permit ipv6 host 2012:1:CA1:22::2 any
    end
    Router R2, R3, R4 & R5
    R2R3R4R5
    hostname R2
    ip cef
    no ip domain lookup
    interface Serial0/0
    no ip address
    ipv6 address 2012:1:CA1:12::2/64
    ipv6 enable
    clock rate 2000000
    router bgp 22
    bgp router-id 2.2.2.2
    neighbor 2012:1:CA1:12::1 remote-as 100
    neighbor 2012:1:CA1:12::1 ebgp-multihop 2
    address-family ipv6
      neighbor 2012:1:CA1:12::1 activate
    exit-address-family
    end
    hostname R3
    ip cef
    no ip domain lookup
    interface Serial0/0
    no ip address
    ipv6 address 2012:1:CA1:13::3/64
    ipv6 enable
    clock rate 2000000
    router bgp 33
    bgp router-id 3.3.3.3
    neighbor 2012:1:CA1:13::1 remote-as 100
    neighbor 2012:1:CA1:13::1 ebgp-multihop 2
    address-family ipv6
      neighbor 2012:1:CA1:13::1 activate
    exit-address-family
    end
    hostname R4
    ip cef
    no ip domain lookup
    interface Serial0/0
    no ip address
    ipv6 address 2012:1:CA1:14::4/64
    ipv6 enable
    clock rate 2000000
    router bgp 44
    bgp router-id 4.4.4.4
    neighbor 2012:1:CA1:14::1 remote-as 100
    neighbor 2012:1:CA1:14::1 ebgp-multihop 2
    address-family ipv6
      neighbor 2012:1:CA1:14::1 activate
    exit-address-family
    end
    hostname R5
    ip cef
    no ip domain lookup
    interface Serial0/0
    no ip address
    ipv6 address 2012:1:CA1:15::5/64
    ipv6 enable
    clock rate 2000000
    router bgp 55
    bgp router-id 5.5.5.5
    neighbor 2012:1:CA1:15::1 remote-as 100
    neighbor 2012:1:CA1:15::1 ebgp-multihop 2
    address-family ipv6
      neighbor 2012:1:CA1:15::1 activate
    exit-address-family
    end
    Verification
         show bgp ipv6 unicast summary
         show bgp ipv6 unicast peer-group
         show ipv6 route bgp
    References
    Implementing Multiprotocol BGP for IPv6
    Border Gateway Protocol
    IP Version 6 (IPv6
    IPv6 Frequently Asked Questions (FAQ)
