teegeorg
Description of the issue
Multicast Receivers are unable to receive traffic initiated by the Multicast source.
Verify if your device configuration matches the following configuration.
##### FE1  ########
ip routing
ip multicast-routing vrf Engineering
ip pim vrf Engineering rp-address 200.2.3.100
ip pim vrf Engineering register-source Loopback500
interface Loopback0
 description Fabric Node Router ID
 ip address 70.0.0.1 255.255.255.255
ip router isis
vrf definition Engineering
 rd 1:4099
 address-family ipv4
  route-target export 1:4099
  route-target import 1:4099
 exit-address-family
interface Vlan1021
 mac-address 0000.5000.5000 < ---- Anycast MAc for gateway
 vrf forwarding Engineering
 ip address 100.1.1.1 255.255.255.0 <---- Anycast Gateway IP
 ip pim sparse-dense-mode
 no lisp mobility liveness test
 lisp mobility v4eid
interface Loopback500
 ip address 153.3.3.3 255.255.255.255
 ip pim sparse-mode
end
router lisp
 locator-set rloc_set1
  IPv4-interface Loopback0 priority 10 weight 10
  auto-discover-rlocs
  exit-locator-set
 service ipv4
  encapsulation vxlan
  map-cache-limit 5119
  database-mapping limit dynamic 3000
  itr map-resolver 71.0.0.1
  etr map-server 71.0.0.1 key key1
  etr map-server 71.0.0.1 proxy-reply
  etr
  sgt
  proxy-itr 70.0.0.1
  use-petr 71.0.0.1
  exit-service-ipv4
instance-id 4097
  remote-rloc-probe on-route-change
  service ipv4
   eid-table default
   exit-service-ipv4
  exit-instance-id
 instance-id 4099
  dynamic-eid v4eid
   database-mapping 100.1.0.0/16 locator-set rloc_set1
   exit-dynamic-eid
  service ipv4
   eid-table vrf Engineering
database-mapping 153.3.3.3/32 locator-set rloc_set1 < — To register the address used by PIM source to the LISP MS/MR
map-cache 0.0.0.0/0 map-request
   exit-service-ipv4
  exit-instance-id
 ipv4 locator reachability exclude-default
 ipv4 source-locator Loopback0
 exit-router-lisp
interface LISP0.4099
 ip pim sparse-mode
##### FE2  ########
ip routing
interface Loopback0
 ip address 70.0.0.2 255.255.255.255
ip router isis
 rd 1:4099
 address-family ipv4
 exit-address-family
interface Vlan1021
 lisp mobility v4eid
 ip address 153.3.3.4 255.255.255.255
 ip pim sparse-mode
end
router lisp
  auto-discover-rlocs
  exit-locator-set
 service ipv4
  encapsulation vxlan
  etr
  sgt
  proxy-itr 70.0.0.2
  use-petr 71.0.0.1
  exit-service-ipv4
instance-id 4097
  service ipv4
   eid-table default
   exit-service-ipv4
  exit-instance-id
 instance-id 4099
  dynamic-eid v4eid
   exit-dynamic-eid
  service ipv4
database-mapping 153.3.3.4/32 locator-set rloc_set1 < — To register the address used by PIM source to the LISP MS/MR
   exit-service-ipv4
  exit-instance-id
 exit-router-lisp
 ip pim sparse-mode
##### FB1  ########
ip routing
interface Loopback0
 ip address 71.0.0.1 255.255.255.255
ip router isis
 rd 1:4099
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
interface Loopback1021 ----- ( Anycast gateway IP configured for DHCP OFFER punt)
 ip address 100.1.1.1 255.255.255.255
 ip address 200.2.3.100 255.255.255.255
 ip pim sparse-mode
end
interface Vlan 2001
 ip address 200.0.0.1 255.255.255.0
 ip pim sparse-mode
end
router lisp
  auto-discover-rlocs
  exit-locator-set
 service ipv4
  encapsulation vxlan
  etr
  sgt
  proxy-etr
  proxy-itr 71.0.0.1
  map-server
  map-resolver
  exit-service-ipv4
instance-id 4097
  service ipv4
   eid-table default
   route-export site-registrations
   distance site-registrations 250
   map-cache site-registration
   exit-service-ipv4
  exit-instance-id
 instance-id 4098
  service ipv4
   eid-table vrf DEFAULT_VN
   exit-service-ipv4
exit-instance-id
 instance-id 4099
  service ipv4
database-mapping 200.2.3.100/32 locator-set rloc_set1 < — To register the RP address to the LISP MS/MR
route-import database bgp 65001 route-map database locator-set rloc_set1 ( — Replacement of redistribute bgp under router ospf)
   exit-service-ipv4
  exit-instance-id
 site site_uci
  authentication-key key1
  eid-record instance-id 4097 0.0.0.0/0 accept-more-specifics
  eid-record instance-id 4098 0.0.0.0/0 accept-more-specifics
  eid-record instance-id 4099 0.0.0.0/0 accept-more-specifics
  exit-site
 exit-router-lisp
 ip pim sparse-mode
router bgp 65001
 bgp router-id interface Loopback0
 bgp log-neighbor-changes
 bgp graceful-restart
address-family ipv4 vrf vn1
  network 173.168.127.1 mask 255.255.255.255
  network 200.2.3.100 mask 255.255.255.255 < ---- To advertise the RP address to upstream routers
  aggregate-address 173.168.227.0 255.255.255.0 summary-only
  aggregate-address 173.168.127.0 255.255.255.0 summary-only
  neighbor 200.0.0.2 remote-as 65002
  neighbor 200.0.0.2 activate
 exit-address-family
route-map database permit 10
 match ip address prefix-list external_prefix
ip prefix-list external_prefix seq 5 permit 200.0.0.0/8
Solution
Run the commands in the Post-SDA Troubleshooting to verify your device configuration. Fix errors, if any.
Pre-SDA Troubleshooting
show ip mroute vrf <vrf_name>
show ip mfib vrf <vrf_name>
  1. Check if the PIM tunnel is up.
    ===== FE1 ======
    FE1#show  ip pim  vrf Engineering tunnel
    Tunnel3
      Type       : PIM Encap
      RP         : 200.2.3.100
      Source     : 153.3.3.3
      State      : UP
      Last event : Created (00:07:29)
  2.  Ensure IGMP joins are received on the Fabric node connected to the Multicast receiver.
    FE1#show  ip igmp  vrf Engineering groups  226.1.1.1 detail
    Flags: L - Local, U - User, SG - Static Group, VG - Virtual Group,
           SS - Static Source, VS - Virtual Source,
           Ac - Group accounted towards access control limit
    Interface: Vlan1021
    Group: 226.1.1.1
    Flags: L U
    Uptime: 00:01:50
    Group mode: EXCLUDE (Expires: 00:02:27)
    Last reporter: 100.1.1.10
    Source list is empty
  3. Verify if RPF check passes for RP address.
    FE1#show  ip rpf vrf Engineering 200.2.3.100
    RPF information for ? (200.2.3.100)
      RPF interface: LISP0.4099
      RPF neighbor: ? (71.0.0.1)
      RPF route/mask: 200.2.3.100/32
      RPF type: unicast ()
      Doing distance-preferred lookups across tables
      RPF topology: ipv4 multicast base
  4. Verify the output on receipt of joins from receiver and before sending traffic from source.
    FE1#show  ip mroute  vrf Engineering 226.1.1.1
    IP Multicast Routing Table
    Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
           L - Local, P - Pruned, R - RP-bit set, F - Register flag,
           T - SPT-bit set, J - Join SPT, M - MSDP created entry, E - Extranet,
           X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
           U - URD, I - Received Source Specific Host Report,
           Z - Multicast Tunnel, z - MDT-data group sender,
           Y - Joined MDT-data group, y - Sending to MDT-data group,
           G - Received BGP C-Mroute, g - Sent BGP C-Mroute,
           N - Received BGP Shared-Tree Prune, n - BGP C-Mroute suppressed,
           Q - Received BGP S-A Route, q - Sent BGP S-A Route,
           V - RD & Vector, v - Vector, p - PIM Joins on route,
           x - VxLAN group, c - PFP-SA cache created entry,
           * - determined by Assert
    Outgoing interface flags: H - Hardware switched, A - Assert winner, p - PIM Join
     Timers: Uptime/Expires
     Interface state: Interface, Next-Hop or VCD, State/Mode
    (*, 226.1.1.1), 00:01:34/00:02:58, RP 200.2.3.100, flags: SJCL
      Incoming interface: LISP0.4099, RPF nbr 71.0.0.1 < — RLOC of FB1
      Outgoing interface list:
        Vlan1021, Forward/Sparse-Dense, 00:01:34/00:02:58
  5. Verify S, G entry after starting traffic from the source.
    FE1#show  ip mroute  vrf Engineering 226.1.1.1 < —
    (*, 226.1.1.1), 00:21:37/stopped, RP 200.2.3.100, flags: SJCL
        Vlan1021, Forward/Sparse-Dense, 00:21:37/00:02:15
    (200.5.6.100, 226.1.1.1), 00:02:12/00:00:47, flags: JT <---- S,G entry after traffic sent from source
        Vlan1021, Forward/Sparse-Dense, 00:02:12/00:02:15
  6. Verify traffic hitting the mfib entry.
    FE1#show  ip mfib  vrf Engineering  226.1.1.1
    Entry Flags:    C - Directly Connected, S - Signal, IA - Inherit A flag,
                    ET - Data Rate Exceeds Threshold, K - Keepalive
                    DDE - Data Driven Event, HW - Hardware Installed
                    ME - MoFRR ECMP entry, MNE - MoFRR Non-ECMP entry, MP - MFIB
                    MoFRR Primary, RP - MRIB MoFRR Primary, P - MoFRR Primary
                    MS  - MoFRR  Entry in Sync, MC - MoFRR entry in MoFRR Client.
    I/O Item Flags: IC - Internal Copy, NP - Not platform switched,
                    NS - Negate Signalling, SP - Signal Present,
                    A - Accept, F - Forward, RA - MRIB Accept, RF - MRIB Forward,
                    MA - MFIB Accept, A2 - Accept backup,
                    RA2 - MRIB Accept backup, MA2 - MFIB Accept backup
    Forwarding Counts: Pkt Count/Pkts per second/Avg Pkt Size/Kbits per second
    Other counts:      Total/RPF failed/Other drops
    I/O Item Counts:   FS Pkt Count/PS Pkt Count
    VRF Engineering
     (*,226.1.1.1) Flags: C HW
       SW Forwarding: 0/0/0/0, Other: 0/0/0
       HW Forwarding:   625/0/104/0, Other: 0/0/0
       LISP0.4099 Flags: A NS
       Vlan1021 Flags: F IC NS
         Pkts: 0/0
     (200.5.6.100,226.1.1.1) Flags: HW
       HW Forwarding:   2523851/9899/104/8043, Other: 0/0/0 <---- Verify counters incrementing for S,G entry
       LISP0.4099 Flags: A
         Pkts: 0/0
  7. Repeat steps on FE2.
    ==== FE2 ====
    FE2#show  ip pim  vrf Engineering tunnel
    Tunnel3
      Type       : PIM Encap
      RP         : 200.2.3.100
      Source     : 153.3.3.4
      State      : UP
    FE2#show  ip igmp  vrf Engineering groups  226.1.1.1 detail
    Interface: Vlan1021
    Group: 226.1.1.1
    Flags: L U
    Uptime: 00:01:50
    Last reporter: 100.1.1.11
    FE2#show  ip rpf vrf Engineering 200.2.3.100
    FE2#show  ip mroute  vrf Engineering 226.1.1.1 <--- Output  on Sending joins from receiver and  before sending traffic from source)
        Vlan1500, Forward/Sparse-Dense, 00:01:34/00:02:58
    FE2#show  ip mroute  vrf Engineering 226.1.1.1 < — Verify S,G entry after starting traffic from source
    FE2#show  ip mfib  vrf Engineering  226.1.1.1
    VRF vrf5000
         Pkts: 0/0
       LISP0.4099 Flags: A
         Pkts: 0/0
  8. Repeat steps on Fabric Border (FB)
    ==== FB1 ====
    FB1#show  ip pim  vrf Engineering tunnel
    Tunnel5
      Type       : PIM Encap
      RP         : 200.2.3.100*
      Source     : 200.2.3.100
      State      : UP
      Last event : Created (02:39:37)
    Tunnel7*
      Type       : PIM Decap
      RP         : 200.2.3.100*
      Source     : -
      State      : UP
    FBR#show  ip mroute  vrf Engineering 226.1.1.1 <--- Output  on Sending joins from receiver and  before sending traffic from source)
    (*, 226.1.1.1), 00:04:39/00:03:03, RP 200.2.3.100, flags: S
      Incoming interface: Null, RPF nbr 0.0.0.0
        LISP0.4099, 70.0.0.1, Forward/Sparse, 00:04:39/00:03:03 < ---- 2 entries as there are 2 receivers behind 2 FEs
          LISP0.4099, 70.0.0.2, Forward/Sparse, 00:04:39/00:03:03 <-----
    SG-FBR1#show  ip mroute  vrf vrf5000 226.1.1.1 <---- Verify S,G entry after starting traffic from source
    (*, 226.1.1.1), 00:26:17/00:03:02, RP 200.2.3.100, flags: S
        LISP0.4099, 70.0.0.1, Forward/Sparse, 00:26:17/00:03:02
         LISP0.4099, 70.0.0.2, Forward/Sparse, 00:26:17/00:03:02
    (200.5.6.100, 226.1.1.1), 00:06:03/00:01:55, flags: T
      Incoming interface: Vlan2001, RPF nbr 200.0.0.2
        LISP0.4099, 70.0.0.1, Forward/Sparse, 00:06:03/00:03:02
         LISP0.4099, 70.0.0.2, Forward/Sparse, 00:06:03/00:03:02
    FB1#show  ip mfib vrf Engineering  226.1.1.1
    VRF Engineering
       HW Forwarding:   3/0/84/0, Other: 0/0/0
       Tunnel7 Flags: A
       LISP0.4099, 70.0.0.1 Flags: F NS
         Pkts: 0/0
       HW Forwarding:   8428458/10000/99/7812, Other: 0/0/0
       Vlan2001 Flags: A
       LISP0.4099, 70.0.0.1Flags: F NS
         Pkts: 0/0
      LISP0.4099, 70.0.0.2Flags: F NS
         Pkts: 0/0
