SunilKhanna
    Introduction
    This document shows how to redistribute Internal BGP routes into OSPF process. Like in other IGP to IGP redistribution the behavior is different when redistributing IBGP into OSPF. IBGP learned routes are not forwarded to an IGP routing protocol through the redistribute command. Use command “bgp redistribute-internal” under the BGP process on the redistributing router.
    In the scenario depicted here, router R1 and R2 are running IBGP and router R2/R3 running OSPF Area 0. R1 is advertising two routes (1.1.1.1 /32 and 172.16.0.0 /16) through network command. R2 is redistributing BGP into OSPF area 0. It is required to redistribute selected internal routes (172.16.0.0 /16). The task is achieved by making use of prefix-list and route-map.
    A prefix-list, named B2O, is configured on R2 to match the prefix 172.16.0.0
                  ip prefix-list B2O seq 5 permit 172.16.0.0/16
    A route-map, named BGP-To_OSPF, is configured on R2
                route-map BGP-To_OSPF permit 10
                  match ip address prefix-list B2O
    In the vrification section, please check the output of "show ip route" command on R3.
    Prerequisite
    • Understanding of routing protocols – BGP and OSPF
    Topology Diagram
    Configuration
    Router R1
    interface Loopback0
    ip address 1.1.1.1 255.255.255.255
    interface Loopback1
    ip address 172.16.1.1 255.255.0.0
    interface Serial1/0
    ip address 192.12.12.1 255.255.255.0
    serial restart-delay 0
    router bgp 100
    no synchronization
    bgp router-id 1.1.1.1
    bgp log-neighbor-changes
    network 1.1.1.1 mask 255.255.255.255
    network 172.16.0.0
    neighbor 192.12.12.2 remote-as 100
    no auto-summary
    Router R2
    interface Loopback0
      ip address 2.2.2.2 255.255.255.255
    interface Serial1/0
      ip address 192.12.12.2 255.255.255.0
    interface FastEthernet2/0
      ip address 192.23.23.2 255.255.255.0
      duplex auto
      speed auto
    router ospf 1
      router-id 2.2.2.2
      log-adjacency-changes
      redistribute bgp 100 metric 100 metric-type 1 subnets route-map BGP-To_OSPF
      network 192.23.23.2 0.0.0.0 area 0
    router bgp 100
      no synchronization
      bgp router-id 2.2.2.2
      neighbor 192.12.12.1 remote-as 100
      no auto-summary
    Router R3
    interface FastEthernet1/0
      ip address 192.23.23.3 255.255.255.0
      duplex auto
      speed auto
    router ospf 1
    network 192.23.23.3 0.0.0.0 area 0
    Verification Commands
    R1#sh ip bgp sum
    BGP router identifier 1.1.1.1, local AS number 100
    BGP table version is 3, main routing table version 3
    2 network entries using 240 bytes of memory
    2 path entries using 104 bytes of memory
    1/1 BGP path/bestpath attribute entries using 124 bytes of memory
    0 BGP route-map cache entries using 0 bytes of memory
    0 BGP filter-list cache entries using 0 bytes of memory
    BGP using 468 total bytes of memory
    BGP activity 2/0 prefixes, 2/0 paths, scan interval 60 secs
    Neighbor        V           AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
    192.12.12.2     4          100     117     119        3    0    0 01:43:47        0
    R2#sh ip bgp sum
    BGP router identifier 2.2.2.2, local AS number 100
    BGP table version is 4, main routing table version 4
    192.12.12.1     4          100     119     118        4    0    0 01:43:36        2
    R2#sh ip bgp
    BGP table version is 4, local router ID is 2.2.2.2
    Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
                  r RIB-failure, S Stale
    Origin codes: i - IGP, e - EGP, ? - incomplete
       Network          Next Hop            Metric LocPrf Weight Path
    *>i1.1.1.1/32       192.12.12.1              0    100      0 i
    *>i172.16.0.0       192.12.12.1              0    100      0 i
    R2#sh ip ospf ne
    Neighbor ID     Pri   State           Dead Time   Address         Interface
    192.23.23.3       1   FULL/DR         00:00:35    192.23.23.3     FastEthernet2/0
    R2#sh ip route 172.16.0.0
    Routing entry for 172.16.0.0/16
      Known via "bgp 100", distance 200, metric 0, type internal
      Redistributing via ospf 1
      Advertised by ospf 1 metric 100 metric-type 1 subnets route-map BGP-To_OSPF
      Last update from 192.12.12.1 01:01:54 ago
      Routing Descriptor Blocks:
      * 192.12.12.1, from 192.12.12.1, 01:01:54 ago
          Route metric is 0, traffic share count is 1
          AS Hops 0
          MPLS label: none
    R3#sh ip route
    Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
           D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
           N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
           E1 - OSPF external type 1, E2 - OSPF external type 2
           i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
           ia - IS-IS inter area, * - candidate default, U - per-user static route
           o - ODR, P - periodic downloaded static route, + - replicated route
    Gateway of last resort is not set
    O E1  172.16.0.0/16 [110/101] via 192.23.23.2, 00:57:55, FastEthernet1/0
          192.23.23.0/24 is variably subnetted, 2 subnets, 2 masks
    C        192.23.23.0/24 is directly connected, FastEthernet1/0
    L        192.23.23.3/32 is directly connected, FastEthernet1/0
    Related Information
    This document helped me a lot.
    j.r.mohanty
    Community Member
    Very useful Document. Nice One
    alnajaba
    Great Example, I was stuck with a ospf redistribution.
    Here  I found the cause. and how to accomplish my task.
    thanks a lot.
    Mohan_Rajesh
    Community Member
    What are the LSA types we see when we redistribute BGP into OSPF?
    Brian B
    should be the same as from any other protocol.  Type 5 (or 7 if into an NSSA).
    Here is output from a router with an eBGP neighbor advertising 8.8.8.8/32 and two iBGP neighbors.  The router is redistributing BGP into OSPF with default options only.  As you can see below, the route is present on the redistributing router as an eBGP route (AD 20) and is advertised to OSPF neighbors as an E2 route by default.  If it were an NSSA, the type would be N2.  With route-maps or options on the redistribute command we could make it an E1/N1.
    R3#sh run | s router ospf
    router ospf 1
    router-id 3.3.3.3
    redistribute bgp 123 subnets
    network 3.3.3.3 0.0.0.0 area 0
    network 10.10.0.0 0.0.255.255 area 0
    R3#sh run | s router bgp
    router bgp 123
    bgp router-id 3.3.3.3
    neighbor iBGP peer-group
    neighbor iBGP remote-as 123
    neighbor iBGP update-source Loopback3
    neighbor iBGP next-hop-self
    neighbor 1.1.1.1 peer-group iBGP
    neighbor 2.2.2.2 peer-group iBGP
    neighbor 38.38.38.8 remote-as 8
    maximum-paths ibgp 2
    R3#sh ip ro 8.8.8.8
    Routing entry for 8.8.8.8/32
    Known via "bgp 123", distance 20, metric 0
    Tag 8, type external
    Advertised by ospf 1 subnets
    Last update from 38.38.38.8 00:00:55 ago
    * 38.38.38.8, from 38.38.38.8, 00:00:55 ago
    AS Hops 1
    Route tag 8
    MPLS label: none
    R3#sh ip bgp 8.8.8.8
    BGP routing table entry for 8.8.8.8/32, version 2
    Paths: (1 available, best #1, table default)
    Multipath: iBGP
    Advertised to update-groups:
    Refresh Epoch 1
    8
    38.38.38.8 from 38.38.38.8 (8.8.8.8)
    Origin incomplete, metric 0, localpref 100, valid, external, best
    rx pathid: 0, tx pathid: 0x0
    R3#sh ip ospf data ext 8.8.8.8
    OSPF Router with ID (3.3.3.3) (Process ID 1)
    Type-5 AS External Link States
    LS age: 74
    Options: (No TOS-capability, DC, Upward)
    LS Type: AS External Link
    Link State ID: 8.8.8.8 (External Network Number )
    Advertising Router: 3.3.3.3
    LS Seq Number: 80000001
    Checksum: 0xED91
    Length: 36
    Network Mask: /32
    Metric Type: 2 (Larger than any link state path)
    MTID: 0
    Metric: 1
    Forward Address: 0.0.0.0
    External Route Tag: 8
    R3#
    chanjohn01
    Hi I'm having the same issue. I'm pretty sure my redistribution from OSPF to BGP is wrong. not able to ping across gi0/0 of PE-1 from PC1. Topology is very similar. Configs and output below:
    ****PE-1******
    vrf definition CustA_HQ
     rd 100:10
     route-target export 100:10
     route-target import 100:10
     route-target import 100:20
     address-family ipv4
     exit-address-family
    vrf definition CustA_Remote
     rd 100:20
     route-target export 100:20
    interface Loopback0
     description ///LOOPBACK0:MPLS-BGP///
    interface Loopback10
     description // VRF CustA_HQ - IGP LOOPBACK //
     ip address 1.1.1.10 255.255.255.255
    interface GigabitEthernet0/0
     ip address 1.1.1.110 255.255.255.254
     ip ospf network point-to-point
     ip ospf 100 area 0
     media-type gbic
     speed 1000
     duplex full
     negotiation auto
    interface GigabitEthernet1/0
     vrf forwarding CustA_HQ
     ip address 10.1.1.10 255.255.255.0
     negotiation auto
    router ospf 10 vrf CustA_HQ
     router-id 1.1.1.10
     log-adjacency-changes detail
     redistribute bgp 100 metric 100 subnets route-map BGP_TO_OSPF
     network 1.1.1.10 0.0.0.0 area 0
     network 10.1.1.0 0.0.0.255 area 0
    router ospf 100
     router-id 1.1.1.1
     network 1.1.1.1 0.0.0.0 area 0
    router bgp 100
     neighbor 2.2.2.2 remote-as 100
     neighbor 2.2.2.2 update-source Loopback0
     address-family ipv4
      neighbor 2.2.2.2 activate
      neighbor 2.2.2.2 send-community extended
     exit-address-family
     address-family vpnv4
     exit-address-family
     address-family ipv4 vrf CustA_HQ
      network 10.1.1.0 mask 255.255.255.0
      redistribute ospf 10 metric 5
     exit-address-family
    ip prefix-list BGP_INTERNAL seq 5 permit 1.1.1.110/31
    route-map BGP_TO_OSPF permit 10
     match ip address prefix-list BGP_INTERNAL
    %%%%%%%%%%PE-1 PINGS%%%%%%%%%%%%%
    PE-1#ping vrf CustA_HQ 10.1.1.10
    Sending 5, 100-byte ICMP Echos to 10.1.1.10, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/8 ms
    Sending 5, 100-byte ICMP Echos to 10.1.1.1, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 16/28/48 ms
    PE-1#ping vrf CustA_HQ 1.0.0.1
    Sending 5, 100-byte ICMP Echos to 1.0.0.1, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 16/28/40 ms
    PE-1#ping vrf CustA_HQ 1.0.0.2
    Sending 5, 100-byte ICMP Echos to 1.0.0.2, timeout is 2 seconds:
    Success rate is 80 percent (4/5), round-trip min/avg/max = 24/299/1084 ms
    %%%%%%%%%%%%%PE-1 ROUTES%%%%%%%%%%%%
    PE-1#
    PE-1#sh ip int brief
    Interface                   IP-Address      OK?    Method  Status                Protocol
    GigabitEthernet0/0     1.1.1.110       YES    manual    up                    up
    GigabitEthernet1/0     10.1.1.10       YES    manual    up                    up
    Loopback0                  1.1.1.1          YES    manual    up                    up
    Loopback10                1.1.1.10        YES    manual    up                    up
    PE-1#
    PE-1#sh ip route
          1.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
    C        1.1.1.1/32 is directly connected, Loopback0
    C        1.1.1.10/32 is directly connected, Loopback10
    C        1.1.1.110/31 is directly connected, GigabitEthernet0/0
    L        1.1.1.110/32 is directly connected, GigabitEthernet0/0
          2.0.0.0/32 is subnetted, 1 subnets
    O        2.2.2.2 [110/2] via 1.1.1.111, 03:12:06, GigabitEthernet0/0
          111.0.0.0/32 is subnetted, 1 subnets
    C        111.111.111.10 is directly connected, Loopback1
    PE-1#
    PE-1#sh ip bgp vpnv4 all
    BGP table version is 3, local router ID is 1.1.1.10
    Route Distinguisher: 100:10 (default for vrf CustA_HQ)
     *>  1.0.0.0/29       10.1.1.1                 5         32768 ?
     *>  10.1.1.0/24      0.0.0.0                  0         32768 I
    ***********************CustA-HQ*********************
    hostname CustA-HQ
     rd 100:10
     address-family ipv4
     exit-address-family
     rd 100:20
    ip cef
    no ipv6 cef
     ip address 10.10.10.10 255.255.255.255
     ip address 10.1.1.1 255.255.255.0
     media-type gbic
     speed 1000
     duplex full
     negotiation auto
     ip address 1.0.0.1 255.255.255.248
     duplex full
     router-id 10.10.10.10
     network 1.0.0.0 0.0.0.7 area 0
     network 10.10.10.10 0.0.0.0 area 0
    control-plane
    end
    CustA-HQ#sh ip route vrf CustA_HQ
    Routing Table: CustA_HQ
          1.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
    C        1.0.0.0/29 is directly connected, FastEthernet1/0
    L        1.0.0.1/32 is directly connected, FastEthernet1/0
          10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
    C        10.1.1.0/24 is directly connected, GigabitEthernet0/0
    L        10.1.1.1/32 is directly connected, GigabitEthernet0/0
          10.0.0.0/32 is subnetted, 1 subnets
    C        10.10.10.10 is directly connected, Loopback10
    CustA-HQ#sh ip ospf neighbor
    1.1.1.10          1   FULL/DR         00:00:34    10.1.1.10       GigabitEthernet0/0
    CustA-HQ#
    CustA-HQ#sh ip route vrf CustA_HQ 1.1.1.110
    % Subnet not in table
    CustA-HQ#
    CustA-HQ#
    CustA-HQ#sh ip route 1.1.1.110
    % Network not in table
    CustA-HQ#
    %%%%PINGS FROM PC CONNECTED TO CustA-HQ%%%%%%
    PC1> ping 1.0.0.1
    84 bytes from 1.0.0.1 icmp_seq=1 ttl=255 time=9.051 ms
    84 bytes from 1.0.0.1 icmp_seq=2 ttl=255 time=9.007 ms
    PC1> ping 10.1.1.1
    84 bytes from 10.1.1.1 icmp_seq=1 ttl=255 time=15.626 ms
    84 bytes from 10.1.1.1 icmp_seq=2 ttl=255 time=15.626 ms
    PC1> ping 10.1.1.10
    84 bytes from 10.1.1.10 icmp_seq=1 ttl=254 time=46.878 ms
    84 bytes from 10.1.1.10 icmp_seq=2 ttl=254 time=31.246 ms
    PC1> ping 1.1.1.110
    *1.0.0.1 icmp_seq=1 ttl=255 time=15.626 ms (ICMP type:3, code:1, Destination host unreachable)
    Me also...
    Esam Alaslmy
    Thanks a lot
    I did not know about "bgp redistribute-internal"
    It was all what I needed
