ITA Terms
Community Member
Description
Small Form-factor pluggable
Definition
Small form-factor pluggable (SFP) is a compact optical transceiver. Cisco Transceiver Modules support Ethernet, Sonet/SDH and Fibre Channel applications across all Cisco switching and routing platforms. Cisco pluggable transceivers offer a convenient and cost effective solution for the adoption in data center, campus, metropolitan area access and ring networks, and storage area networks. Cisco portfolio of hot pluggable interfaces offers a rich set of choices in terms of speeds, protocols, reaches and supported transmission media.
Models
Cisco 10 Gigabit Modules
Cisco CWDM Transceiver Modules
Cisco DWDM Transceiver Modules
Cisco Fast Ethernet SFP Modules
Cisco Gigabit Ethernet GBIC/SFP Modules
Cisco SONET/SDH SFP Modules
Cisco Gigabit Ethernet Transceiver Modules Compatibility Matrix
Maintenance and Troubleshooting
can we use a Finisar FTLF1318P3BTL single mode SFP in a Nexus 9000 line card N9K-X97160YC-EX?
Michael Borbon
Hi Team,
I just want to ask questions if the SFP-10G-T-X  will work with C9200L-24T-4X-E switches. Thanks!
Rich R
@DouglasRyda46883 and @Michael Borbon you should use https://tmgmatrix.cisco.com/ to lookup compatibility between SFPs and specific hardware platforms.
You should also cross-reference with the product documentation and software release notes for that platform because there are sometimes also software version dependencies (a particular SFP might only be supported from a specific release of software).
