Dear All,
When I use the show interface command on the Cisco Router ISR-4331, it will display as below information. The word that I mark red, it refresh every 5 seconds. But, I compare with the old router model like a Cisco 29XX or 28XX, it can be refresh every 1 second. Is there anyone know how to change the refresh interval on Cisco router 4331 ("bootflash:/isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bi")?
Thanks.
#sh int g0/0/0
GigabitEthernet0/0/0 is up, line protocol is up
Hardware is ISR4331-3x1GE, address is 2cab.eb85.91a0 (bia 2cab.eb85.91a0)
Description:
Internet address is 10.51.20.85/30
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive not supported
Full Duplex, 100Mbps, link type is force-up, media type is RJ45
output flow-control is on, input flow-control is on
Last input 00:00:04, output 00:06:58, output hang never
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 95000 bits/sec, 87 packets/sec
30 second output rate 80000 bits/sec, 61 packets/sec
511816539 packets input, 75629622593 bytes, 0 no buffer
Received 1465 broadcasts (161977042 IP multicasts)
0 watchdog, 162302013 multicast, 0 pause input
76183480 packets output, 12080277968 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
