Setting up failover on ASA in production
jkay18041
Level 3
Level 3
I currently have an ASA in production and have a question about setting it up in Active Passive failover.
I've got a 2nd unit that is the same with same firmware and everything. If I want to setup the passive unit will it cause downtime?
My current unit is setup like this
G0/0 WAN
G0/1 and G0/2 are in a port-channel for the LAN
G0/5 is a connection to another ASA with a Local IP.
I'm assuming all 3 would need a secondary IP? and then I would need to make G0/2 the lan failover port and G0/3 the State failover port? so I would need secondary IP's for those as well I know.
For G0/1- 02 since they are in a port-channel when I set this up will it break the port channel?
Thank you for the help
Hello
Yes it is indeed applicable to to have ASA HA, to dom this suggest to pick a spare interface (fastest) on each asa and use that as the fail-over link between the two ASA.
Basically all you need to do it setup the fail-over on the priamry asa and when you ready attached the secondary asa initiate failover.
Each interface on the primary will be the same on the secondary.
ASA1
int x/x
nameif outside
ip address 1.1.1.1 255.255.255.0 secondary 1.1.1.2
int x.x
nameif inside
ip address 10.10.10.1 255.255.255.0 secondary 10.10.10.2
int x.x
nameif DMZ
ip address 11.11.11.1 255.255.255.0 secondary 11.11.11.2
int gig 1/1  (Failover link)
no shut
exit
failover lan unit primary
failover lan interface Failover gig1/1
failover interface ip Failover 172.16.1,1 255.255.255.0 standby 172.16.1.2
failover key ASAFO
ASA2
Just make sure all interfaces are activated on secondary ASA that relate to the primary ASA ( these should be the exact same interfaces as above but they DONT need to be configured just enabled)
int x/x
no shut
exit.......
no shut
exit
(only config required on ASA2)
failover lan unit secondary
failover key ASAFO
Connect the two asa's together and instate the HA replication (apply to both fw's)
ASA1/2
conf t
failover
Once initiated then the ASA's will replicate with each other
show failover
prompt hostname priority state -- <--this will show you what FW your currency connected to in the future
Optionally you can also have a stateful link between the two fw's but youll require an additional spare interface
ASA1/2
int gig1/2
no shut
exit
failover link stateful-FO gig1/2
failover interface ip stateful-FO 172.16.2.1 255.255.255.252 standby 172.16.2.2
Kind Regards
Paul
Mark Elsen
 - I am very skeptic as to doing this , procedural or not. Even it could be accomplished it will be difficult to establish whether you now have real fail over configuration afterwards. Such 'projects' must be realized before the ASA-pair servers a production network (then also testing can be done).
 M.
Since we decided to do this after the fact it's about the only option we have.
Do you know if we do this will it kill the etherchannel that is setup for our LAN?
Hello
ASA1
int x/x
nameif outside
int x.x
nameif inside
int x.x
nameif DMZ
no shut
exit
failover key ASAFO
ASA2
int x/x
no shut
exit.......
no shut
exit
failover key ASAFO
ASA1/2
conf t
failover
show failover
ASA1/2
int gig1/2
no shut
exit
Kind Regards
Paul
