Meddane
Download BGP Routing Protocol With 16 Practice Labs.
Table of Contents
Lab 1: MED and AS-Path Prepend
Lab 2: BGP Local Preference
Lab 3: BGP path control
Lab 4: BGP Confederations
Lab 5: Bestpath as-path ignore and aggregate-address
Lab 6: Community Attribute AS-Path Prepend and Default route
Lab 7: BGP Backdoor and AS-Path Prepend
Lab 8: AS-Path Prepend Weight and Default route
Lab 9: Community Attribute and Route Reflector
Lab 10: BGP Peer Group Community Attribute and Local Preference
Lab 11: MP-BGP Local Preference Weight and Community Attribute
Lab 12: MP-BGP OSPFv3 and Attributes Manipulation
Lab 13: BGP Confederation weight and Unsuppress-map
Lab 14: BGP Conditional advertisement
Lab 15: Route Aggregation Attribute-map and Advertise-map
Lab 16: BGP ORF (Outbound Route Filtering) capability
Martin L
thanks; any chance to get pre-config files ?
Meddane
Hi @Martin L  at the top of each lab you the basic configuration of all routers so that you can copy and past.
Martin L
what IOS version(s) have you used for this lab ?
Any chances that BGP behavior/commands may vary between IOS'es ?
thanks
Regards, ML
**Please Rate All Helpful Responses **
Meddane
Use router IOS 15.X.
ndowebartholomew
Community Member
Helping
Just wanted to say thank you.
twmoody
Frequent Visitor
Frequent Visitor
Just completed the first two labs.   Great work.   Labs are organized, easier to follow than a lot of the pay labs I have seen.   Great explanations.    Thanks for the hard work you put into this doc.
Meddane
@twmoody You are welcome, I am happy to see that the labs are helpful..
trevorc1653
Frequent Visitor
Frequent Visitor
These are awesome labs!!!
Meddane
@trevorc1653 You are welcome...
SamuraiEx
Frequent Visitor
Frequent Visitor
hi @Meddane ,
I am starting on these labs today and pretty excited. I finished the other ones on redistribution and suboptimal routing yesterday night.
From the bottom of my heart, I just want to say thank you. Your labs are really helping me understand alot practically!
BR,
ibev
Community Member
@Meddane
Thanks so much for the labs. These are really cool.
ibev
meixiaoting
Community Member
sdino
Frequent Visitor
Frequent Visitor
Hi @Meddane,
Thank you so much for sharing this LAB, just right on time due going to review my BGP routing knowledge (i.e. go through Cisco U e-learning, read the e-book and do LAB practice) and got 5 units of ISR1100-4GLTE that just recently migrated to IOS-XE 17.9.8 as autonomous.
