ycit
I have cisco WS-C4500X-16. When I power off a few minute, switch stuck in rommon mode. And then I plug off power and plug in and then switch can boot os. Why switch cannot boot os when power off a few minute(10minutes).
!!!Rommon mode log!!!
Switch#▒
* Rom Monitor NVRAM configuration is being initialized to *
* default values. This may be because it was never initialized.*
Writing to Primary Region failed
Writing to Backup Region failed
Rommon (G) Signature verification PASSED
flash0:/codesign/rm1.dat open failure
Rommon (P) Signature verification PASSED
flash0:/codesign/rm2.dat open failure
FPGA (P) Signature verification PASSED
flash0:/codesign/fpga.dat open failure
* Welcome to Rom Monitor for WS-C4500X-16 System. *
* Copyright (c) 2008-2013 by Cisco Systems, Inc. *
* All rights reserved. *
Rom Monitor (P) Version 15.0(1r)SG10
CPU Rev: 2.2, Board Rev: 9, Board Type: 108
CPLD Mobat Rev: 2.0x549a.0x59a4
Chassis: WS-C4500X-16
MAC Address : c0-8c-60-6d-4e-a7
Ip Address : Not set.
Netmask : Not set.
Gateway : Not set.
TftpServer : Not set.
Non-Redundant system or peer not running IOS
System Uplinks & Linecards have been reset!!
***** The system will autoboot in 5 seconds *****
Type control-C to prevent autobooting.
Management Ethernet Link Up: 10Mb Full Duplex
******** The system will autoboot now ********
config-register = 0x102
Autobooting using BOOT variable specified file.....
Could not find a valid file in BOOT environment variable.
BOOT variable can be set from IOS. To find currently set
Rom Monitor variables, please type 'set' command.
For help on choosing a boot method, type 'confreg' command.
rommon 1 >
Leo Laohoo
In ROMMON, do the following
confreg 0x2102
And then reboot the switch.
ycit
@Leo Laohoo Cannot type confreg 0x2102 in rommon mode
rommon 3 >confreg 0x2102
usage: confreg
rommon 4 >dir bootflash:
Date Time Attribute Size Name
2000/01/06 21:50 -rw-rw-rw- 34 pnp-tech-time
2000/01/06 21:50 -rw-rw-rw- 94291 pnp-tech-discovery-summary
2000/01/08 00:50 -rw-rw-rw- 200826928 cat4500e-universalk9.SPA.03.11.02.E.152-7.E2.bin
2000/01/08 20:49 drwxrwxrwx 4096 pxe
2000/06/23 01:06 drwxrwxrwx 4096 scripts
2000/06/23 01:06 drwxrwxrwx 4096 virtual-instance
2000/06/23 01:06 drwxrwxrwx 4096 vman_fdb
2000/06/23 01:06 drwxrwxrwx 4096 virtual-instance-stby-sync
2017/10/01 04:29 -rw-rw-rw- 178950332 cat4500e-universalk9.SPA.03.06.07.E.152-2.E7.bin
2000/06/23 02:23 -rw-rw-rw- 1976 startup-config.converted_vs-20000623-022253
2000/01/01 00:20 -rw-rw-rw- 3293 startup-config.converted_vs-20000101-002018
2000/01/01 04:33 -rw-rw-rw- 6313 startup-config.converted_vs-20000101-043331
2000/01/28 18:03 -rw-rw-rw- 1157 JAE173301H0_20230621103306920.lic
2000/01/30 10:15 -rw-rw-rw- 3893 startup-config.converted_vs-20000130-101526
2000/01/30 10:47 -rw-rw-rw- 6747 startup-config.converted_vs-20000130-104703
2000/01/08 01:52 -rw-rw-rw- 4493 startup-config.converted_vs-20000108-015214
Total space = 1645217 KB
Available = 1280820 KB
ycit
@Leo Laohoo
I cannot type confreg 0x2102 in rommon mode.
usage: confreg
usage: confreg
rommon 9 >confreg
Configuration Summary :
=> load rom after netboot fails
=> console baud: 9600
=> autoboot from: commands specified in 'BOOT' environment variable
do you wish to change the configuration? y/n [n]:
Leo Laohoo
Post the complete output to the ROMMON command of "set".
ycit
@Leo Laohoo
rommon 1 >set
PS1=rommon ! >
RommonVer=15.0(1r)SG10
SupportedFeatures=1
ConfigReg=0x0102
ycit
@Leo Laohoo
I changed configReg=0x2102 like that and boot firmware from tftp server. Switch can boot os. And then A few minute power off, return back to rommon mode.
rommon 20 >confreg
=> diagnostic mode
=> ignore system config info
do you wish to change the configuration? y/n [n]: y
disable "diagnostic mode"? y/n [n]: y
enable "use net in IP bcast address"? y/n [n]:
enable "load rom after netboot fails"? y/n [n]: y
enable "use all zero broadcast"? y/n [n]:
enable "break/abort has effect"? y/n [n]:
disable "ignore system config info"? y/n [n]: y
change console baud rate? y/n [n]:
change the boot characteristics? y/n [n]: y
enter to boot:
0 = disable autoboot
1 = the first file from internal flash device
2 = commands specified in 'BOOT' environment variable
[2]: 2
do you wish to save this configuration? y/n [n]: y
You must reset or power cycle for new configuration to take effect
rommon 21 >set
PS1=rommon ! >
SupportedFeatures=1
ConfigReg=0x2102
rommon 22 >set interfaces fa1 192.168.100.1 255.255.255.0
Set commands:
set interface use 'set interface help' for more info on how
to set IpAddr and other networking parameters
set ip use 'set ip help' for more info on how
to set Gateway variable for default route
set TftpServer use 'set TftpServer help' for more info
To set an arbitrary Rom Monitor variable to some value
please type 'variable=value' directly (without set).
rommon 23 >set interface fa1 192.168.100.1 255.255.255.0
rommon 24 >set ip route default 192.168.100.2
rommon 25 >set
PS1=rommon ! >
SupportedFeatures=1
ConfigReg=0x2102
IpAddr=192.168.100.1
Netmask=255.255.255.0
Broadcast=192.168.100.255
Gateway=192.168.100.2
rommon 26 >boot tftp://192.168.100.2/cat4500e-universalk9.SPA.03.11.02.E.152-7.E2.bin
Tftp Session details are ....
Filename : /cat4500e-universalk9.SPA.03.11.02.E.152-7.E2.bin
IP Address : 192.168.100.1
Loading from TftpServer: 192.168.100.2
TftpBlkSize : 1468
RxDataPacket : 136804
Loaded 200826928 bytes successfully.
Checking digital signature....
[/cat4500e-universalk9.SPA.03.11.02.E.152-7.E2.bin]
Digitally Signed Release Software with key version A
flash0:/codesign/ios.dat open failure
Rommon reg: 0x00084F80
Reset2Reg: 0x00004200
ExtX super block invalid signature
Image load status: 0x00000005
Radtrooper 064 controller 0x047F44FC..0x04990096 Size:0x00661EDC
Program Done!
[ 0.091181] pci 0000:00:00.0: ignoring class b20 (doesn't match header type 01)
[ 0.181418] pci 0001:04:00.0: ignoring class b20 (doesn't match header type 01)
[ 0.274017] pci 0002:0c:00.0: ignoring class b20 (doesn't match header type 01)
Starting System Services
devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=4,mode=600,ptmxmode=000 0 0
diagsk10-post version 5.1.4.2
prod: WS-C4500X-16 part: 73-14786-04 serial: JAE173301H0
Power-on-self-test for Module 1: WS-C4500X-16
CPU Subsystem Tests ...
seeprom: Pass
Traffic: L3 Loopback ...
Test Results: Pass
Traffic: L2 Loopback ...
Test Results: Pass
post done(55 secs)
Exiting to ios...
Continuing with IOS boot..
Jan 8 22:18:53 %IOSXE-3-PLATFORM: process kernel: [ 87.678715] mpc85xx_pci_err_probe: Unable to requiest irq 0 for MPC85xx PCI err
Jan 8 22:18:53 %IOSXE-3-PLATFORM: process kernel: [ 87.692568] mpc85xx_pcie_err_probe: Unable to requiest irq 0 for MPC85xx PCIe err
Loading gsbu64atomic as gdb64atomic
Loading pds_kc_flowcntl for kstack
loading kstack module
Loading container module
Using 1 for MTS slot
Platform Manager: starting in VSS mode (chassis id 1, in-chassis active)
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.11.02.E RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Sat 14-Mar-20 21:52 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
Initializing as Virtual Switch ACTIVE processor
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C4500X-16 (MPC8572) processor (revision 9) with 4194304K bytes of physical memory.
Processor board ID JAE173301H0
MPC8572 CPU at 1.5GHz, Cisco Catalyst 4500X
Last reset from PowerUp
1 Virtual Ethernet interface
16 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Press RETURN to get started!
*Jan 8 22:19:19.664: %BUFCAP-6-EPC_RF_INFRA: EPC rf infra registration is SUCCESS
*Jan 8 22:19:25.087: %C4K_IOSSYS-6-IMAGELEVEL: Supervisor booting in image level 'entservices'
*Jan 8 22:19:31.594: %C4K_IOSMODPORTMAN-4-POWERSUPPLYBAD: Power supply 1 has failed or been turned off
*Jan 8 22:22:07.606: %VSLP-5-RRP_PEER_TIMEOUT: VSLP peer timer expired without detecting peer. Resolving role as Active
*Jan 8 22:22:07.627: %C4K_SWITCHINGENGINEMAN-6-BFDINVALIDPACKETACLAPPLIED: Control plane protection against invalid BFD packets is applied
*Jan 8 22:22:37.693: %C4K_REDUNDANCY-6-INIT: Initializing as ACTIVE supervisor
*Jan 8 22:22:39.231: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Jan 8 22:22:41.139: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 1 (WS-C4500X-16 S/N: JAE173301H0 Hw: 1.1) is online
*Jan 8 22:22:45.369: %SPANTREE-6-PORTDEL_ALL_VLANS: Port-channel1 deleted from all Vlans
*Jan 8 22:22:45.548: %SYS-5-CONFIG_I: Configured from memory by consoleSystem has been configured
*Jan 8 22:22:45.748: %SYS-5-RESTART: System restarted --
*Jan 8 22:22:50.809: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
Switch>en
Switch#sh bootvar
BOOT variable = bootflash:cat4500e-universalk9.SPA.03.11.02.E.152-7.E2.bin,12;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Configuration register is 0x102
Standby not ready to show bootvar
Switch#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)#no boot sy
Switch(config)#$ash:cat4500e-universalk9.SPA.03.11.02.E.152-7.E2.bin,12
Switch(config)#config-re
Switch(config)#config-register
% Incomplete command.
Switch(config)#config-register 0x2102
Switch(config)#$:cat4500e-universalk9.SPA.03.11.02.E.152-7.E2.bin
Switch(config)#do sh bootvar
Configuration register is 0x102 (will be 0x2102 at next reload)
Switch(config)#exit
Switch#
*Jan 8 22:25:57.383: %SYS-5-CONFIG_I: Configured from console by console
Switch#wirte mem
% Invalid input detected at '^' marker.
Switch#write mem
Building configuration...
Compressed configuration from 4666 bytes to 2459 bytes[OK]
Switch#reload
Proceed with reload? [confirm]
*Jan 8 22:26:23.713: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload command.
*Jan 8 22:26:24.135: %IOSXE-3-PLATFORM: 1 process sysmgr: Reset/Reload requested by [console].
<Sat Jan 8 22:26:24 2000> Message from sysmgr: Reason Code:[3] Reset Reason:Reset/Reload requested by [console]. [Reload command]
umount: /proc/fs/nfsd: not mounted
/tmp/sw/mount/cat4500e-base.SPA.03.11.02.E.pkg:m
Please stand by while rebooting the system...
[ 575.079994] Restarting system.
IP Address : 192.168.101.2
Netmask : 255.255.255.0
Gateway : 192.168.101.1
config-register = 0x2102
Current BOOT file is --- bootflash:cat4500e-universalk9.SPA.03.11.02.E.152-7.E2.bin
Loading image !!!!!!!!!!!!!!!!!!!!!!!!!
[bootflash:/cat4500e-universalk9.SPA.03.11.02.E.152-7.E2.bin]
Image load status: 0x00000003
Program Done!
[ 0.061679] pci 0000:00:00.0: ignoring class b20 (doesn't match header type 01)
[ 0.151909] pci 0001:04:00.0: ignoring class b20 (doesn't match header type 01)
[ 0.244519] pci 0002:0c:00.0: ignoring class b20 (doesn't match header type 01)
seeprom: Pass
Test Results: Pass
Test Results: Pass
post done(56 secs)
Exiting to ios...
Jan 8 22:30:01 %IOSXE-3-PLATFORM: process kernel: [ 85.186029] mpc85xx_pci_err_probe: Unable to requiest irq 0 for MPC85xx PCI err
Jan 8 22:30:01 %IOSXE-3-PLATFORM: process kernel: [ 85.197978] mpc85xx_pcie_err_probe: Unable to requiest irq 0 for MPC85xx PCIe err
cisco Systems, Inc.
software.
export@cisco.com.
Last reset from Reload
*Jan 8 22:30:27.887: %BUFCAP-6-EPC_RF_INFRA: EPC rf infra registration is SUCCESS
*Jan 8 22:30:33.296: %C4K_IOSSYS-6-IMAGELEVEL: Supervisor booting in image level 'entservices'
*Jan 8 22:30:39.746: %C4K_IOSMODPORTMAN-4-POWERSUPPLYBAD: Power supply 1 has failed or been turned off
*Jan 8 22:33:16.054: %VSLP-5-RRP_PEER_TIMEOUT: VSLP peer timer expired without detecting peer. Resolving role as Active
*Jan 8 22:33:16.074: %C4K_SWITCHINGENGINEMAN-6-BFDINVALIDPACKETACLAPPLIED: Control plane protection against invalid BFD packets is applied
*Jan 8 22:33:46.074: %C4K_REDUNDANCY-6-INIT: Initializing as ACTIVE supervisor
*Jan 8 22:33:47.608: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Jan 8 22:33:49.539: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 1 (WS-C4500X-16 S/N: JAE173301H0 Hw: 1.1) is online
*Jan 8 22:33:53.735: %SPANTREE-6-PORTDEL_ALL_VLANS: Port-channel1 deleted from all Vlans
*Jan 8 22:33:53.917: %SYS-5-CONFIG_I: Configured from memory by consoleSystem has been configured
*Jan 8 22:33:54.136: %SYS-5-RESTART: System restarted --
*Jan 8 22:33:59.219: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
Switch>
Switch>
Switch>en
Switch#sh bootvar
Switch#write mem
Compressed configuration from 4666 bytes to 2453 bytes[OK]
Switch#write mem
Switch#dir
Directory of bootflash:/
161602 -rw- 34 Jan 6 2000 21:50:45 +00:00 pnp-tech-time
161603 -rw- 94291 Jan 6 2000 21:50:48 +00:00 pnp-tech-discovery-summary
161604 -rw- 200826928 Jan 8 2000 00:50:06 +00:00 cat4500e-universalk9.SPA.03.11.02.E.152-7.E2.bin
193921 drwx 4096 Jan 8 2000 22:30:00 +00:00 pxe
193923 drwx 4096 Jun 23 2000 01:06:17 +00:00 scripts
16164 drwx 4096 Jun 23 2000 01:06:39 +00:00 virtual-instance
32321 drwx 4096 Jun 23 2000 01:06:39 +00:00 virtual-instance-stby-sync
161606 -rw- 178950332 Oct 1 2017 04:29:09 +00:00 cat4500e-universalk9.SPA.03.06.07.E.152-2.E7.bin
161605 -rw- 1976 Jun 23 2000 02:23:11 +00:00 startup-config.converted_vs-20000623-022253
161607 -rw- 3293 Jan 1 2000 00:20:22 +00:00 startup-config.converted_vs-20000101-002018
161608 -rw- 6313 Jan 1 2000 04:33:35 +00:00 startup-config.converted_vs-20000101-043331
161609 -rw- 1157 Jan 28 2000 18:03:16 +00:00 JAE173301H0_20230621103306920.lic
161610 -rw- 3893 Jan 30 2000 10:15:30 +00:00 startup-config.converted_vs-20000130-101526
!!!!!!!!When I power off switch a few minute and switch return back to rommon configReg 0x102 !!!!!!
Netmask : Not set.
Gateway : Not set.
rommon 1 >
Management Ethernet Link Down!
Management Ethernet Link Up: 100Mb Full Duplex
rommon 1 >set
PS1=rommon ! >
SupportedFeatures=1
ConfigReg=0x0102
ycit
I power off a few minute and then power on first time, switch stuck in rommon mode but when I power off and power on quickly, switch can load os.
Leo Laohoo
Switch is dead.
ycit
Hardware issue or something?
Leo Laohoo
The switch is dead.
