Mohamed Sayed
hi all
I have two cores 4507R with sup iv running IOS
cat4500-entservicesk9-mz.122-31.SGA11.bin
I configured VRRP between them
I found that some of the edges that connected on the two cores are down
I cannot ping these switches and I can not telnet them
no error in the interfaces no cdp neighbor signal
how can I find the problem ??
Mohamed Sayed
the problem was in the fiber cables and it is solved by solving the fiber cables.
