Hi All
Looking for a little help. I have just received several of the switches above to install onto my network. This is the first time I have used Managed Switches. So I used the documentation to connect to the switch and enter Express Setup. I give the Switch an IP address, the Subnet of my network and the default gateway and also give it a host name, then I save this information.
Unfortuantly after this I can not see the Switch on the IP Address I have assigned or the default IP address of 10.0.0.1. I have made sure all the information i have entered into the switch is correct, I have even rest the switch and started again, but still the same thing happens. I thought it may be the switch itself, so I tried another switch, but the same thing happens. I am a little lost.
The switch itself is working, as I have connected devices to the switch and I can ping the device itself, I can ping to the device and from the device on the switch to anywhere on the network, I just cant ping the switch itself.
Douglas Bell
