Do you mean
Cisco Works - Applications and Versions -
by VIP Alumni on ‎09-02-2010 05:40 AM
this document tries to give an overview about all the applications and versions released with CiscoWorks starting from LMS 2.0 up to LMS 3.2.
First there is the LMS version. Under this point I listed the different applications and their versions when a fresh installation is done.
Second I listed the updates available for the different applications which changes the version number for this application. The maximum version number for each application within each relase of LMS is listed in square brackets [ ].
The prerequisites for installing the individual application upgrades are not conequently listed - for this you need to read the installation guide for each patch. I can give no guarantee that this is a complete and correct listing but I did my best and hopefully it can help someone to find his way through the labyrinth of LMS versions and application versions and sub-versions...
CiscoWorks
Applications and Version Numbers
== CiscoWorks 2000  ==. 1
CiscoWorks 2000 LMS 2.0 Applications and Versions. 1
CiscoWorks 2000 LMS 2.1 Applications and Versions. 1
CiscoWorks 2000 LMS 2.2 Applications and Versions. 1
== Cisco Works Lan Management Solution==. 1
LMS 2.5 Applications and Versions. 1
Application Updates for LMS 2.5. 1
LMS 2.5.1 Applications and Versions (Maintenance Update over LMS 2.5) 2
Application Updates for LMS 2.5.1. 2
LMS 2.6 Applications and Versions (Maintenance Update over LMS 2.5.1) 2
Application Updates for LMS 2.6. 3
LMS 3.0 Applications and Versions. 3
Application Updates for LMS 3.0. 3
LMS 3.0.1 Applications and Versions (Maintenance update over LMS 3.0) 4
Application Updates for LMS 3.0.1. 4
LMS 3.1 Applications and Versions. 4
Application Updates for LMS 3.1. 5
LMS 3.2 Applications and Versions. 5
Application Updates for LMS 3.2. 5
LMS 3.2.1 Applications and Versions (Service Pack 1 for LMS 3.2). 5
==== LMS 4.0 ====
LMS 4.0 The New Interface
LMS 4.0.1
CiscoWorks CD one 4th Edition
                CMF 2.0
Resource Manager Essentials 3.3
Campus Manager 3.1
Device Fault Manager 1.1
nGenius RealTime Monitor 1.3
CiscoView (Part of CD one) 5.3
CiscoWorks CD one 5th Edition
                CMF 2.1
Resource Manager Essentials 3.4
Campus Manager 3.2
Device Fault Manager 1.2
nGenius RealTime Monitor 1.4
                Fault History 1.1
CiscoView (Part of CD one) 5.4
CiscoWorks Common Services 2.2
                CMF 2.2
Resource Manager Essentials 3.5
Campus Manager 3.3
                Fault History 1.1.1
CiscoView (Part of CD one) 5.5
== CiscoWorks Lan Management Solution==
CiscoWorks Common Services 3.0
Resource Manager Essentials 4.0                   [4.0.2]
Campus Manager 4.0                                     [4.0.2]
Device Fault Manager 2.0
Internetwork Performance Monitor 2.6
CiscoView (Part of CD one) 6.1
(provided as Service Packs/Software Updates)
Upgrade Resource Manager Essentials from RME 4.0 to 4.0.2
                Windows:            cwrme4_0_2_win.zip
                Solaris:               cwrme4_0_2_sol.zip
Upgrade Campus Manager from CM 4.0 to CM 4.0.2
                Windows :           cwcm4_0_2_win.zip
                Solaris :              cwcm4_0_2_sol.zip
DFM 2.x Upgrade Kit (for LMS 2.5 and LMS 2.5.1)
                Windows:            cw-dfm-20-UpgradeKit-win.zip
                Solaris:               cw-dfm-20-UpgradeKit-sol.zip
CiscoWorks Common Services 3.0.3
Resource Manager Essentials 4.0.3                  [4.0.4]
Campus Manager 4.0.3                                    [4.0.5]
Device Fault Manager 2.0.3
CiscoView (Part of CD one) 6.1.2
LMS 2.5.1 is a maintenace Update over LMS 2.5
                update package name
                Windows:             lms25_dec2005_update_win.zip
                Solaris:                  lms25_dec2005_update_sol.zip
                prerequesite:        LMS 2.5
Upgrade Resource Manager Essentials from RME 4.0.3 to 4.0.4
                Windows:             cwrme4_0_4_win.zip
                Solaris:                cwrme4_0_4_sol.zip
Upgrade Campus Manager from CM 4.0.3 to CM 4.0.4, CM 4.0.5
                Windows :            cwcm4_0_4_win.zip
                                           cwcm4_0_5_win.zi
                Solaris :               cwcm4_0_4_sol.zip
                                           cwcm4_0_5_sol.zip
                Cummulative update, so only CM 4.0.5 needs to be installed
CiscoWorks Common Services 3.0.5             [CS 3.0.6]
Resource Manager Essentials 4.0.5               [RME 4.0.6]
Campus Manager 4.0.6                                 [CM 4.0.10 > 4.0.13]
Device Fault Manager 2.0.6
CiscoView 6.1.5
LMS 2.6 is a maintenance Update over LMS 2.5.1
                update package name
                Windows:             lms26_update_win_K9.zip
                Solaris:                lms26_update_sol_K9.zip
                prerequisite:         LMS 2.5.1
Application Updates for LMS 2.6 (aka LMS 2.6 SP1)
Upgrade Common Services to 3.0.6
                Windows:             cwcs3_0_6_sol_k9.zip
                Solaris:                cwcs3_0_6_win_k9.zip
                prerequisite:         CS 3.0.5
                download:            http://www.cisco.com/cgi-bin/tablebuild.pl/cd-one-3des
Upgrade Resource Manager Essentials to 4.0.6
                Windows:             cwrme4_0_6_win.zip
                Solaris:                cwrme4_0_6_sol.zip
upgrade for  RME Remote Syslog Collector:
                Windows:             cwrsac4_0_6_win.zip
                Solaris:                cwrsac4_0_6_sol.zip
Upgrade Campus Manager from CM 4.0.6 to CM 4.0.7, CM 4.0.8, CM 4.0.9, CM 4.0.10
                prerequisites for all:            requires CM 4.0.6 and Common Services(CS)3.0.6
                Windows :            cwcm4_0_7_win.zip
        cwcm4_0_8_win.zip
        cwcm4_0_9_win.zip
        cwcm4_0_10_win.zip CM 4.0.10 requires CM4.0.6 and Common Services(CS)3.0.6
                Solaris :               cwcm4_0_7_sol.zip
        cwcm4_0_8_sol.zip
        cwcm4_0_9_sol.zip
        cwcm4_0_10_sol.zip
                Cummulative patches, so only CM 4.0.10 needs to be installed
Upgrade Campus Manager from CM 4.0.10 to CM 4.0.11, CM 4.0.12, CM 4.0.13
                prerequisites for all:            requires that you have CM4.0.10 installed
                Windows :           cwcm4_0_11_win.zip
       cwcm4_0_12_win.zip
       cwcm4_0_13_win.zip
    Solaris :              cwcm4_0_11_sol.zip
       cwcm4_0_12_sol.zip
       cwcm4_0_13_sol.zip
                Cummulative Patches, so only CM 4.0.13 needs to be installed
CiscoWorks LMS Portal 1.0
CiscoWorks Assistant 1.0
CiscoWorks Common Services 3.1
Resource Manager Essentials 4.1
Campus Manager 5.0
Device Fault Manager 3.0                                               [DFM 3.0.1]
Internetwork Performance Monitor 4.0
CiscoView 6.1.6
Note: LMS 3.0 requires a different license than LMS 2.x.  However, all versions of LMS 3.x can use the same license.
Upgrade Device Fault Manager from DFM 3.0 to 3.0.1
                Windows :            cwdfm3_0_1_win.zip
                Solaris :               cwdfm3_0_1_sol.zip
Upgrade Campus Manager from CM 5.0 to CM 5.0.1
                Windows :            cwcm5_0_1_win.zip
                Solaris :               cwcm5_0_1_sol.zip
CiscoWorks LMS Portal 1.0.1
CiscoWorks Assistant 1.0.1
CiscoWorks Common Services 3.1.1
Resource Manager Essentials 4.1.1
Campus Manager 5.0.2                                    [CM 5.0.6]
Device Fault Manager 3.0.2                              [DFM 3.0.5]
Internetwork Performance Monitor 4.0.1
CiscoView 6.1.7
Integration Utility 1.7.1
HUM 1.0
(when installing the maintenance update, option to install HUM along with the update – but can be installed later also)
LMS 3.0.1 is a maintenance Update over LMS 3.0 and includes 90-day evaluation Version of Health and Utilization Monitor 1.0:
                update package name: (also called “December 2007 update”)
                Windows:             lms30_dec07_update_win_k9.zip
                Solaris:                lms30_dec07_update_sol_k9.zip
                prerequisite:         LMS 3.0
Upgrade Health and Utilization Monitor to 1.0.2.  This update brings 64-bit counter support.
               Windows:              hum1_0_2_win.zip
               Solaris:                 hum1_0_2_sol.zip
Upgrade Campus Manager from CM 5.0.2 to 5.0.3, 5.0.4, 5.0.5, 5.0.6
                Windows :            cwcm5_0_3_win.zip
        cwcm5_0_4_win.zip
        cwcm5_0_5_win.zip
        cwcm5_0_6_win.zip         (requires CM5.0.2 and CS 3.1.1)
                Solaris :               cwcm5_0_3_sol.zip
        cwcm5_0_3_sol.zip
        cwcm5_0_4_sol.zip
        cwcm5_0_5_sol.zip
        cwcm5_0_6_sol.zip           (requires CM5.0.2 and CS 3.1.1)
                the CM patches are cummulative, so only CM 5.0.6 needs to be installed
Upgrade Device Fault Manager from 3.0.2 to 3.0.3, 3.0.4, 3.0.5 (DFM 3.0.5 is required for Windows to fix some very severe bugs)
                Windows :            cwdfm3_0_3_win.zip
        cwdfm3_0_4_win.zip
        cwdfm3_0_5_win.zip
                Solaris :               cwdfm3_0_3_sol.zip
        cwdfm3_0_4_sol.zip
        cwdfm3_0_5_sol.zp
CiscoWorks LMS Portal 1.1
CiscoWorks Assistant 1.1
CiscoWorks Common Services 3.2
Resource Manager Essentials 4.2
Campus Manager 5.1                                       [CM 5.1.4]
Device Fault Manager 3.1                                 [DFM 3.1.3]
Internetwork Performance Monitor 4.1
CiscoView 6.1.8
Integration Utility 1.8
Health and Utilization Monitor 1.1
Upgrade Campus Manager from CM 5.1 to 5.1.1, 5.1.3, 5.1.4
                Windows :            cwcm5_1_1_win.zip
        cwcm5_1_3_win.zip
        cwcm5_1_4_win.zip
                Solaris :               cwcm5_1_1_sol.zip
        cwcm5_1_3_sol.zip
        cwcm5_1_4_sol.zip
Upgrade Device Fault Manager  to 3.1.1, 3.1.2, 3.1.3
                Windows :            cwdfm3_1_1_win.zip
                                           cwdfm3_1_2_win.zip
                                           cwdfm3_1_3_sol.zip
                Solaris :               cwdfm3_1_1_sol.zip
                                           cwdfm3_1_2_sol.zip
                                           cwdfm3_1_3_sol.zip
Upgrade Health and Utilization Monitor to 1.1.2.  This include suppport for 64-bit counters.
                Windows:           hum1_1_2_win.zip
                Solaris:               hum1_1_2_sol.zip
CiscoWorks LMS Portal 1.2
CiscoWorks Assistant 1.2
CiscoWorks Common Services 3.3
Resource Manager Essentials 4.3                   [RME 4.3.1]
Campus Manager 5.2                                     [CM 5.2.1]
Device Fault Manager 3.2
Internetwork Performance Monitor 4.2
CiscoView 6.1.9
Integration Utility1.9
Health and Utilization Monitor 1.2                    [HUM 1.2.1]
download link (evaluation version):
     LMS_3.2_Windows
     LMS_3.2_Solaris
Upgrade Resource Manager Essentials (RME) 4.3.1 EnergyWise support over CiscoWorks RME 4.3
                Windows:             rme4_3_1_win.zip
                Solaris:                rme4_3_1_sol.zip
CAUTION! can introduce Bug CSCtd45156 (Patch available from TAC, will be pulished on Cisco Bug ToolKit)
Upgrade Campus Manager to 5.2.1
                Windows :            cwcm5_2_1_win.zip
                Solaris :               cwcm5_2_1_sol.zip
Upgrade Health and Utilization Monitor (HUM) 1.2.1, which includes EnergyWise support over HUM 1.2
               Windows:             hum1_2_1_win.zip
               Solaris:                 hum1_2_1_sol.zip
(proivded as a Service Pack for LMS 3.2)
prerequisite: RME 4.3.1, CM 5.2.1, HUM 1.2.1
CiscoWorks LMS Portal 1.2.1
CiscoWorks Common Services 3.3.1
Resource Manager Essentials 4.3.2
Campus Manager 5.2.2
Device Fault Manager 3.2.1
Internetwork Performance Monitor 4.2.1
CiscoView 6.1.9
Integration Utility 1.9
Health and Utilization Monitor 1.2.1
download
     windows:    ciscoworks_lms321_win_k9.zip
     solaris:       ciscoworks_lms321_sol_k9.zip
=======================   LMS 4.0   =======================
LMS 4.0 - THE NEW INTERFACE
NOTE! needs a different licenses than LMS 3.x
Functions instead of Applications
Starting with LMS 4.0 the GUI of LMS is reorganized - focusing on functions (e.g. Monitor, Asset, Configuration) instead of applications (e.g. Campus Manager, Resource Manager). As a consequence, there are some basic changes:
     - the application and version schema does not exist anymore
     - patches are bundled and provided in a different way
     - you can only install LMS as a whole (not e.g. the "Monitor" Functions on a seperate server as the "Configuration" function)
     LMS_4.0_Windows
     LMS_4.0_Solaris
LMS 4.0.1
patch over LMS 4.0
     windows:     cwlms4_0_1_win_k9.zip
     solaris:        cwlms4_0_1_sol_k9.zip
by Cisco Employee
on ‎09-02-2010 08:33 AM
Great job, Martin.  Any chance you can turn this document from a PDF into inline content in CSC?  The reason I ask is that I see some opportunities for extension.  For example, you left out HUM 1.2.1 that came as part of the LMS 3.2 EnergyWise drop-in (along with RME 4.3.1).  I would love to collaborate with you on completing a few minor things.
by VIP Alumni
on ‎09-02-2010 09:26 AM
thanks, Joe! I yet tried to share it as an inline content first, but the format was not that good when I copied it from the original version into the online editor and I struggled with some details - but I think this second try is ok ..
I would be pleased about if you help to keep this document up to date and make it more useful ! So feel free to edit what you think can or should be changed!
by Level 4
on ‎04-18-2012 02:33 AM
thanks for the document
by Cisco Employee
on ‎08-12-2013 12:49 AM
Thsi is a wonderful document Martin! I guess its time for update it to version 8 with LMS 4.2.x details and CPI future connection to be mentioned here.
