kumarkrishnar
Visitor
Any one help what are the process running Cat4k Mgmt LoPri
switch#show processes cpu | exclude 0.00
CPU utilization for five seconds: 92%/1%; one minute: 42%; five minutes: 41%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
  27    32784036  31364685       1045  0.31%  0.15%  0.14%   0 Per-Second Jobs
  29  1715584900 687773096       2494  9.18%  9.34%  9.27%   0 Cat4k Mgmt HiPri
  30   8269736802210380461        374 73.56% 28.31% 27.47%   0 Cat4k Mgmt LoPri
  39     5110688   8291234        616  0.07%  0.06%  0.07%   0 Compute load avg
  52   203071728  49890440       4070  0.79%  0.89%  0.89%   0 Spanning Tree
  57   142609988  79037812       1804  6.54%  0.97%  0.77%   0 Port-Security
  60    20206140 166827636        121  0.23%  0.39%  0.35%   0 CDP Protocol
  62         456       293       1556  0.23%  0.08%  0.03%   1 SSH Process
102    10607112 746652781         14  0.15%  0.20%  0.21%   0 PM Callback
switch#
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I5K91S-M), Version 12.2(25)EWA7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 16-Oct-06 18:43 by dchih
Image text-base: 0x10000000, data-base: 0x115FE9A4
ROM: 12.1(12r)EW
Dagobah Revision 95, Swamp Revision 24
switch uptime is 1 year, 22 weeks, 13 hours, 26 minutes
Uptime for this control processor is 1 year, 22 weeks, 13 hours, 35 minutes
System restarted at 22:19:48 IST Sun Aug 17 2008
System image file is "bootflash:cat4000-i5k91s-mz.122-25.EWA7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C4507R (MPC8245) processor (revision 5) with 524288K bytes of memory.
Processor board ID XXXXXXX
MPC8245 CPU at 333Mhz, Supervisor IV
Last reset from PowerUp
6 Virtual Ethernet interfaces
240 FastEthernet interfaces
2 Gigabit Ethernet interfaces
403K bytes of non-volatile configuration memory.
I checked cisco site  the current running IOS is defered release
regards
krishna
m-goedderz
Visitor
Hi Krishna,
There is a link for background information and how to troubleshoot high cpu utilazation for c4500.
High CPU Utilization on Cisco IOS Software-Based Catalyst 4500 Switches
Grüezi
Michael
