Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
You can try searching on the internet and you might get lucky. Best if you know the name of the image you're looking for and whether you're looking for autonomous (standalone) or controller based (lightweight) AP IOS. For example: autonomous: c1140-k9w7-tar.153-3.JD17.tar lightweight: c1140-k9w8-tar.153-3.JD17.tar
