01-18-2013 03:16 AM - edited 03-01-2019 04:53 PM
Virtual switching system (VSS) can enable on Catalyst 4500/4500X series switch (Supervisor Engine 7-E, Supervisor Engine 7L-E, and Catalyst 4500-X). Cisco IOS XE 3.4.0SG and ROMMON IOS Version 15.0(1r) SG7 later released support VSS. This document discuss about Cisco 4500 SUP7-E ROMMON upgrade.
Step1: You can verify your current ROMMON using “show version” command as shown below. I have dual supervisor engine present in my chassis, so to verify standby supervisor engine ROMMON you can use "show module" command.We are upgrading ROMMON to 15.0(1r)SG7 to run VSS on it.
Switch#sh ver | in IOS
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.01.00.SG RELEASE SOFTWARE (fc4)
Cisco IOS-XE software, Copyright (c) 2005-2010 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
Switch#sh ver | i ROM
ROM: 15.0(1r)SG1
Switch#sh module
Chassis Type : WS-C4510R+E
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
4 48 10/100/1000BaseT Premium POE E Series WS-X4748-RJ45V+E CAT1518L0K5
5 4 Sup 7-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP7-E CAT1506L06A
6 4 Sup 7-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP7-E CAT1602L19X
M MAC addresses Hw Fw Sw Status
4 e8b7.4865.c090 to e8b7.4865.c0bf 1.0 Ok
5 70ca.9b5e.6600 to 70ca.9b5e.6603 1.0 15.0(1r)SG1 03.01.00.SG Ok
6 70ca.9b5e.6604 to 70ca.9b5e.6607 1.1 15.0(1r)SG5 03.01.00.SG Ok
Mod Redundancy role Operating mode Redundancy status
5 Active Supervisor RPR Active
6 Standby Supervisor RPR Standby cold
System Failures:
Step2: You need to download ROMMON Image from Cisco.com. Please find the below path for your information.
Downloads Home > Products > Switches > Campus LAN Switches - Access > Cisco Catalyst 4500 Series Switches > Cisco Catalyst 4510R+E Switch > Cisco Catalyst 4500 Supervisor Engine 7-E > IOS XE ROMMON Software-15.0(1r)SG7
Step3: Then you need to Copy this ROMMON image file into supervisor engine flash (both active as well as standby) from your TFTP server. Before copying file please verify your flash/disk memory space using “Show bootflash:” or “Show slave bootflash:” command to avoid any file transfer failure.
Switch#copy tftp: slavebootflash:
Address or name of remote host [3.3.3.1]?
Source filename [cat4500-e-ios-promupgrade-150-1r-SG7]?
Destination filename [cat4500-e-ios-promupgrade-150-1r-SG7]?
Accessing tftp://3.3.3.1/cat4500-e-ios-promupgrade-150-1r-SG7...
Loading cat4500-e-ios-promupgrade-150-1r-SG7 from 3.3.3.1 (via GigabitEthernet4/46): !!!!!!!!!!
[OK - 2460468 bytes]
2460468 bytes copied in 12.396 secs (198489 bytes/sec)
Verifying ROMMON Images in supervisor engine flash:
Switch#sh bootflash:
-#- --length-- ---------date/time--------- path
1 4096 Jan 17 2013 09:52:09 +00:00 .
2 112337548 Sep 11 2012 01:27:08 +00:00 cat4500e-universal.SPA.03.03.00.SG.151-1.SG.bin
3 86771191 Sep 11 2012 04:10:40 +00:00 cat4500e-universal.SPA.03.02.00.SG.150-2.SG.bin
4 115624136 Sep 11 2012 04:33:00 +00:00 cat4500e-universalk9.SPA.03.03.00.SG.151-1.SG.bin
5 89765939 Sep 11 2012 04:34:50 +00:00 cat4500e-universalk9.SPA.03.02.00.SG.150-2.SG.bin
6 85251784 Jan 15 2013 22:37:27 +00:00 cat4500e-universal.SPA.03.01.00.SG.150-1.XO.bin
7 2460468 Jan 17 2013 09:52:16 +00:00 cat4500-e-ios-promupgrade-150-1r-SG7
296267776 bytes available (493031424 bytes used)
Switch#sh slavebootflash:
1 4096 Jan 17 2013 10:00:21 +00:00 .
2 86771191 Mar 05 2012 21:58:23 +00:00 cat4500e-universal.SPA.03.02.00.SG.150-2.SG.bin
3 90681924 Apr 09 2012 07:01:37 +00:00 cat4500e-universalk9.SPA.03.02.02.SG.150-2.SG2.bin
1.XO.bin
4 2460468 Jan 17 2013 10:00:33 +00:00 cat4500-e-ios-promupgrade-150-1r-SG7
114708480 bytes available (674590720 bytes used)
Step4: Enter the “reload” command to reset the switch and press Ctrl-C within 5 seconds to stop the boot process and you will be in ROMMON mode. Once you reload your active supervisor engine, device standby supervisor engine will become active processor.
Switch#reload
Proceed with reload? [confirm]
*Jan 17 10:05:35.435: %SYS-5-RELOAD: Reload requested by console. Reload reason: Reload commandPlease stand by while rebooting the system...
Restarting system.
Rommon signature verification PASSED for golden image
Rommon signature verification PASSED for primary image
FPGA signature verification PASSED for primary image
* Welcome to Rom Monitor for WS-X45-SUP7-E System. *
* Copyright (c) 2008-2010 by Cisco Systems, Inc. *
* All rights reserved. *
Rom Monitor Program Version 15.0(1r)SG1
CPU Rev: 2.1, Board Rev: 8, Board Type: 101, CPLD Moka Rev: 7.0x2643.0x5956
Chassis: WS-C4510R-E
Got Mac Address: 00:26:0b:79:c3:d2
MAC Address : 00-26-0b-79-c3-d2
Ip Address : Not set.
Netmask : Not set.
Gateway : Not set.
TftpServer : Not set.
***** The system will autoboot in 5 seconds *****
Type control-C to prevent autobooting.
Autoboot cancelled......... please wait!!!
rommon 1 > [interrupt]
rommon 1 >
Below output shows your standby is becoming active.
Switch-standby>
Switchover activity detected, changing role from STANDBY to ACTIVE
Step5: you can use “dir bootflash:” command see to ROMMON file and use “boot booflash:file_name” to get upgrade.
rommon 1 >dir bootflash:
Date Time Attribute Size Name
2012/03/05 21:58 -rw-rw-rw- 86771191 cat4500e-universal.SPA.03.02.00.SG.150-2.SG.bin
2012/04/09 07:01 -rw-rw-rw- 90681924 cat4500e-universalk9.SPA.03.02.02.SG.150-
1.XO.bin
2013/01/17 10:00 -rw-rw-rw- 2460468 cat4500-e-ios-promupgrade-150-1r-SG7
Total space = 808548 KB
Available = 153272 KB
rommon 2 >boot bootflash:cat4500-e-ios-promupgrade-150-1r-SG7
loading image
Checking digital signature
bootflash:/cat4500-e-ios-promupgrade-150-1r-SG7: Digitally Signed Release Software with key version A
* (****** Cisco Internal Use Only ******) *
* Firmware Upgrade for WS-X45-SUP7-E System *
* Copyright (c) 2008-2009, 2012 by Cisco Systems, Inc*
Upgrading images/FPGAs... DO NOT RESET the system
unless instructed or upgrade will fail !!!
Uncompressing image: Cat4K_KeyStorage
Image Name : Cat4K_KeyStorage
Image size : 65536 bytes
Step6: This may happen automatically if the system is. You can also configure auto-boot using “boot system bootflash:cat4500-e-ios-promupgrade-150-1r-SG7” to happened boot process automatically. Be sure you write your config after this command.
Once above supervisor engine booted with new ROMMON image it will become standby supervisor engine and you can verify its image on your active supervisor engine using “Show module” command.
Switch#sh module
5 70ca.9b5e.6600 to 70ca.9b5e.6603 1.0 15.0(1r)SG7 03.01.00.SG Ok
5 Standby Supervisor RPR Standby cold
6 Active Supervisor RPR Active
System Failures:
Step7: Follow the step 4-5 on current active supervisor engine to upgrade its ROMMON. Once it boot it will become standby supervisor engine.
Verifying both supervisor engine ROMMON image:
Switch#sh module
6 70ca.9b5e.6604 to 70ca.9b5e.6607 1.1 15.0(1r)SG7 03.01.00.SG Ok
System Failures:
ROMMON Release Notes for the WS-X45-SUP7-E and WS-C4500X Family of Switches
ROMMON R Notes for WS-X4013+10GE and WS-X4516-10GE
ROM: 15.0(1r)SG1
Switch#sh module
System Failures:
I should be able to use this same process on a WS-4500x-32 running
ROM: 15.0(1r)SG7 with IOS-XE 3.4.0??? ... I attempted to upgrade to IOS-XE 3.5.3, which i rolled back, without the ROM upgrade. I will be going to ROM: 15.0(1r)SG10, that is the correct ROMMON i need to use IOS-XE 3.5.3
Any body has tried this already? Run into any major issues?
There's a SECOND method to use if your console terminal doesn't understand "Ctrl+C". This method means that you set the config-registry value of the supervisor card(s) to "0x2100". Note that if you have a VSS and you set the config-registry value to "0x2100" and reboot, both supervisor cards will go into ROMmon.
If one was to use the "0x2100" registry, make sure you set it back to either "0x2101" or "0x2102" when in ROMmon.
Hello ashirkar,
I have a question. I want to upgrade IOS image and rom at the same time. I created one boot variable which is given below. Please check and let me know if there is nay mistake.
Let take below romupgrade and image.
romupgrade : cat4500-e-ios-promupgrade-151-1r-SG5
image : cat4500es8-universalk9.SPA.03.06.02.E.152-2.E2.bin
boot system flash bootflash:cat4500-e-ios-promupgrade-151-1r-SG5 (new romupgrade )
boot system flash bootflash:cat4500es8-universalk9.SPA.03.06.02.E.152-2.E2.bin(new image)
boot system flash slot0:cat4500-e-ios-promupgrade-151-1r-SG5 (new promupgrade )
boot system flash slot0:cat4500es8-universalk9.SPA.03.06.02.E.152-2.E2.bin(new image)
boot system flash slavebootflash:cat4500-e-ios-promupgrade-151-1r-SG5 (new promupgrade )
boot system flash slavebootflash:cat4500es8-universalk9.SPA.03.06.02.E.152-2.E2.bin(new image)
boot system flash bootflash:OLD IMAGE
boot system flash slot0:OLD IMAGE
boot system flash slavebootflash:OLD IMAGE
Is this correct ?
Do i need to remove romoupgrade boot sequence after ios upgradation ?
Abhijith
This is an important question and the answer is a YES. Failure to do so will mean that when the chassis reboots or powers up it will run the ROMmon upgrade. I have no idea what happens to the supervisor card if it runs a ROMmon upgrade twice but I don't want to find out.
Don't waste time upgrading to SG5 and go with the newer SG11.
Hold on, what are these for? Is the chassis in a VSS? If the chassis is in VSS, then there is no need to do this.
Hello Leo,
Platform is 4510 with redundant supervisor. Each supervisor have two memory location that means boot flash and slot0. My question is that if i want to upgrade code only, are below boot variable enough ??
Abhijith
This boot variable statement is not required. All that matters is the first one. That one is applied on the Primary Supervisor and the the boot variable will automatically apply to the Secondary.
Hi Friends
I am working on catalyst 4507R+E switch in this we are using two SUP7-E(sup engine) but both are not working simultaneously,then i removed 1st SUP engine & removed remaing three slots (POE,SFP,X2-E).Then 2nd SUP engine started & it's continuously booting not loading IOS.I tried to load IOS but no luck below is the console output
Non-Redundant system or peer not running IOS
System Uplinks & Linecards have been reset!!
rommon 1 >
rommon 1 >
2017/09/21 07:42 -rwxrwxrwx 126060564 cat4500e-universalk9.SPA.03.04.04.S G.151-2.SG4.bin
Total space = 827810 KB
Available = 708060 KB
rommon 2 >dir slot0:
No SD card detected!
Error[3]: Failed to open directory!
rommon 3 >boot bootflash:cat4500e-universalk9.SPA.03.04.04.SG.151-2.SG4.bin
Loading image !!!!!!!!!!!!!!!!
Checking digital signature....
[bootflash:/cat4500e-universalk9.SPA.03.04.04.SG.151-2.SG4.bin]
Rommon reg: 0x00004F80
Reset2Reg: 0x00000F00
Image load status: 0x00000000
Snowtrooper 155 controller 0x04506694..0x046B1A69 Size:0x0041DCD4 Program Done!
Linux version 2.6.24.4.3.70.k10 (smuppala@build-lnx-036) (gcc version 4.2.1 p7 ( Cisco c4.2.1-p7)) #1 SMP Fri May 16 10:58:05 PDT 2014
Rommon (G) Signature verification PASSED
Rommon (P) Signature verification PASSED
FPGA (P) Signature verification PASSED
* Copyright (c) 2008-2013 by Cisco Systems, Inc. *
Rom Monitor (P) Version 15.0(1r)SG10
CPU Rev: 2.2, Board Rev: 11, Board Type: 101
CPLD Moka Rev: 7.0x3718.0xb565
Chassis: WS-C4507R+E
MAC Address : 50-0f-80-72-c6-38
Netmask : Not set.
Gateway : Not set.
rommon 1 >reset
Resetting .......
rommon 2 >
Netmask : Not set.
Gateway : Not set.
rommon 1 >dir usb0:
2018/01/03 21:21 D---- 0 Hewlett-Packard
2018/01/03 21:30 D-HS- 0 System Volume Information
2018/01/03 21:30 D-HS- 0 $RECYCLE.BIN
2018/01/04 12:50 ----A 115528896 lw_9.8_single.exe
2018/01/05 08:33 ----A 8576 CA_PA Format.PDF
2018/01/12 11:59 ----A 45099968 softether-vpnclient-v4.24-9652-beta -2017.12.21-windows-x86_x64-intel.exe
2018/01/12 12:00 ----A 47051200 softether-vpnserver_vpnbridge-v4.24 -9652-beta-2017.12.21-windows-x86_x64-intel.exe
2018/01/12 14:51 ----A 1810120 AnyDesk.exe
2018/01/12 11:51 ----A 6277706 softether-vpnclient-v4.24-9652-beta -2017.12.21-linux-x64-64bit.tar.gz
2018/01/12 11:50 ----A 6278134 softether-vpnbridge-v4.24-9652-beta -2017.12.21-linux-x64-64bit.tar.gz
2017/07/12 12:57 ----A 178676676 cat4500e-universalk9.SPA.03.06.05.E .152-2.E5.bin
Total space = 15616992 KB
Available = 15214712 KB
rommon 2 >boot usb0:cat4500e-universalk9.SPA.03.06.05.E.152-2.E5.bin
Loading image !!!!!!!!!!!!!!!!!!!!!!!
[usb0:cat4500e-universalk9.SPA.03.06.05.E.152-2.E5.bin]
Snowtrooper 155 controller 0x044DFA02..0x0468ADD7 Size:0x0041DCD4
Program Done!
[ 0.058289] pci 0000:00:00.0: ignoring class b20 (doesn't match header type 0 1)
Starting System Services
udevd-work[1207]: symlink(hda1, /dev/dcsflash.udev-tmp) failed: File exists
diagsk10-post version 5.1.4.1
Netmask : Not set.
Gateway : Not set.
rommon 1 >
rommon 1 >
rommon 1 >
The same thing happening for another SUP engine also.If i kept all slots in the chassis no of the SUP engine is working & status led is dead condition & utilization led blink in .
I do not issue with SUP engine or Chassis ......Kindly help us solve this issue with priority.
Venugopal
